Audio
johnB
Audio
Post by johnB »
probably a dum question but on my old pc i used to have a single connection (green colour) running from the back of the pc to the monitor.
now on the intense pc pro i can't get this to work using the S/PSIF sockets.
I see the pc pro shipped with an audio cable but that does not interface with the monitor (ViewSonic).
do i need some sort of adapter?
Re: Audio
Are we talking about digital or analog audio? What OS do you have on IntensePC
johnB
Re: Audio
Post by johnB »
Hi, i have 64 bit Window 8.
i'm not that technical so don't know if i'm talking digital or analog but i'm trying to connect to a jack point on the back of the monitor labeled 'audio in'. typically these jack point are colour coded green
johnB
Re: Audio
Post by johnB »
pic of what i mean by the green jack point - see attached.
Re: Audio
Please apply the attached patch, and restart your PC. Check the sound again
Intense-PC_Audio_Patch.zip
(369 Bytes) Downloaded 1307 times
johnB
Re: Audio
Post by johnB »
Thanks Gabrielh,
I'll give it a go and report back.
Cheers,
John
johnB
Re: Audio
Post by johnB »
I ran the reg setting and re-booted. no change ie no sound via the green analogue jack cable.
John
Re: Audio
Please open regedit and look for "ForceDisableJD" string. Change it's value to "01".
johnB
Re: Audio
Post by johnB »
Hi, yes that is already the value there after running the reg file. see screen shot.
Re: Audio
Can you try to use a different speakers? Also, please attach the Sound\Playback tab screenshot
