I just bought a fit-pc2 value diskless. I put an SSD Kingstone drive in it but I can't install, the installation progress hang...
What can I do?
Thanx all!
Can't install
Re: Can't install
- Is your fit-pc working good with a live USB stick ?
- Can you use the Ctrl-Alt-F1 shortcut keys to switch to the first console and see any message ?
- Can you wait a long while to be sure the installation really hangs ?
(Maybe the system is downloading and installing stuffs from Ubuntu repository on the internet and take a while for that ?)
- Can you use another iso image (ubuntu alternate, lubuntu, mint or whatever) ?
Maybe you created a bad image on your USB key (check the md5sum).
Otherwhise, can you explain more ... Can you give more clues ?
Re: Can't install
Hello
Can you please give some more details of the installation process? I.E. OS, install media, the hang up screen?
Re: Can't install
I haven't tried yet.Mylife wrote:- Is your fit-pc working good with a live USB stick ?
I haven't tried yet.Mylife wrote:- Can you use the Ctrl-Alt-F1 shortcut keys to switch to the first console and see any message ?
I've tried to wait 2 hours and without any connection, so yes.Mylife wrote:- Can you wait a long while to be sure the installation really hangs ?
I've tried to install from an external USB DVD, an ASUS SDRW-08D1S-U, with 11.04 Desktop/Server iso and 11.10 Desktop/Server iso.Mylife wrote:- Can you use another iso image (ubuntu alternate, lubuntu, mint or whatever) ?
Mylife wrote:Otherwhise, can you explain more ... Can you give more clues ?
Re: Can't install
I've tried to install from a iso burned on cd downloaded from Ubuntu official site; I've tried Ubuntu 11.04 Desktop/Server and 11.10 Desktop/Server.gabrielh wrote:Hello
The installation hang on the screen attached.
- ubuntu-install-screen-1.png (3.87 KiB) Viewed 18089 times
Re: Can't install
Hello
If you press an "esc" key while you see this screen, is it disappears? Can you post me the installation log prior it hangs up?
Re: Can't install
Now I've installed win xp because I need it in the weekend...
I'll try asap, btw where and how I can see the log?
Re: Can't install
When you press the esc button, and the ubuntu screen is disappears, you should see the log
