Inserting/removing uSD card problem
fmk
Post by fmk »
Is there a trick to it?
The first time since I got my iA10 I tried inserting a uSD card. I pushed it in until it was flush with the case. Nothing. Tried pushing it a little further inside with my fingernail. Still nothing, and now I couldn't get it out. Shut the fitlet down and disconnected power. Used a paperclip to push it a little further. I'm used to a little click noise when the card seats, but I didn't hear anything. Pushed again, and it may have moved back out a little, but not enough to remove it. Finally used some extremely small surgical tweezers to grip it and pull it out.
Arwen
Re: Inserting/removing uSD card problem
Post by Arwen »
For my fitlet-iA10, the plastic slot in the panel was a bit too small. Could not reliably
install and remove a microSD card. So I took off the front panel and on the inside, used
a philips head screw driver to make the inside of the slot slightly larger.
Now the microSD cards install normally. I definantly hear and feel a click when it's
properly inserted.
Of course, since the front panel is a bit thick, getting the card out without a tool, (like
a fingernail or nail file), is a bit hard. But, I'd rather this, than have the card stick out.
Arwen Evenstar
Rivendale, Middle Earth
fitlet incorporates a standard push-push microSD socket. It should click into place on pushing and spring out when pushed again.
If the mechanism fails on your fitlet you may RMA it for replacement.
fmk
Post by fmk »
I tried it some more and found that it does work. There is a lot of free movement up and down when inserting the card and it is easy to be mis-aligned and miss the socket. That's the problem I was having. With care I can now get it to work properly.
ReneFunga
Post by ReneFunga »
genting casino download
Return to “General fitlet questions”
