- does it support low voltage DDR (1,35V) so-dimm?
- do you have a list of certified memory?
Low voltage DDR support
Re: Hardware questions
Low voltage DDR3 may be supported. It is BIOS dependent. We will issue a list of tested DDR3 models.
Re: Low voltage DDR support
AMD's web site says the processor takes DDR3L, which is 1.35V:
http://products.amd.com/en-us/NotebookA ... spx?id=110
So why does the Fitlet spec say 1.5V?
Default RAM support in fitlet was changed to 1.35V. We will update specifications.
Another change regarding fitlet specs.irads wrote:Default RAM support in fitlet was changed to 1.35V. We will update specifications.
No Serial port on fitlet-B. It was in the block diagram and still visible in the pictures.
Now from DDR3 1.5v to DDR3L 1.35
And "late march" is now mid April...
disappointing
Serial port doesn't appear on fitlet-B block diagrams and other official docs.
It did when I bought it.mbirger wrote:Serial port doesn't appear on fitlet-B block diagrams and other official docs.
- fitlet-B-top-level-block-diagram.pdf
- (256.65 KiB) Downloaded 1093 times
I have received the Fitlet-B and I would like to buy a DDR3L module.irads wrote:Low voltage DDR3 may be supported. It is BIOS dependent. We will issue a list of tested DDR3 models.
Have you issued the list you mention? Any suggestion for DDR3 compatible models? 1333 or 1600?
See tested RAM modules list https://docs.google.com/spreadsheets/d/ ... sp=sharing
In the Compatible RAM modules spreadsheet list you state that Crucial CT102464BF160B isn't working in the fitlet, although http://www.crucial.com/usa/en/ct102464b ... uctDetails says that that 8GB memory stick runs with 1.35V. So it should run, shouldn't it?
Did you test this memory stick? Why is it listed as incompatible?
