Suggestion: WLAN FACE module addition?
Nadrek
Post by Nadrek »
May I suggest a pair of FACE module derivatives for Wifi use, and an alternate:
FM-4E.. - for routers that also serve as Wifi access points, keep the 4 Intel ethernet ports, drop the USB ports entirely, and then add 4 (a pair of 2x2 by itself, or 3x3 with the built-in jacks) or 6 (a pair of 3x3 by itself, or 4x4 with the built-in jacks) RP-SMA bulkhead jacks with pigtails. This would allow using a pair of Mini-PCIe wireless cards to their fullest capability.
FM-2MP... - for wifi access points, again, add more RP-SMA jacks to the existing Mini-PCIe FACE module. This would allow 3 120 degree sector antennas plus an omni, or 4 90 degree sector antennas to be used simultaneously.
FM-blank... provide a blank FACE module, just the stamped outline, so we can drill it ourselves.
Re: Suggestion: WLAN FACE module addition?
Thank you for your inquiry and suggestions. We will look what we can do
Return to “General FACE Module questions”
