hi,
Anyone test the spdif out?
The manual mentions compulab P/N 199D10300.
Do you have to use this one? If so where can you buy it?
I did not see it on the site.
It tired a mini adapter I have, but get nothing.
spdif out
Re: spdif out
You should select the Digital Audio (SPDI/F) as an output
Re: spdif out
ok, figured it out
Always check the box ...
I presumed the spdif was a mini toslink connector (optical).
Instead there was a mini jack to RCA coaxial converter cable in the box.
Maybe this needs to be a bit clearer in the documentation or even on the casing, most spdif connections these days are toslink as it is less sensitive to interference.
