Page 1 of 2
Analog audio in??
Posted: Sat Mar 09, 2013 5:10 pm
by IntensePC_User
I'm trying to use the Analog Input on the Intense PC Pro, running Windows 7, 32bit. I do have something plugged into the appropriate audio input port, so that is not the problem.
I've applied the registry update availabled in the Audio Output forum thread following fit-pc's instructions. This did not fix the Analog Input problem. Is there an equivalent registry update to fix this?
As of right now, it appears that Windows only recognizes the following:
Playback: Digital Out (Default), Headphone (Not Plugged In)
Recording: Digital In (Default)
Thanks for your help,
Re: Analog audio in??
Posted: Sat Mar 09, 2013 5:30 pm
by IntensePC_User
Following advice from a user in the "Audio output in Windows 8 on Intense PC" forum thread, I installed the newest drivers directly downloaded from Realtek.
Now I have the following devices after applying your registry patch:
Playback: Digital Out (Ready), Speakers (Default)
Recording: Digital In (Ready), Microphone (Default)
Unfortunately, a "Microphone" input isn't the same as a "Line-In." The Intense PC is marketed as having "Stereo line-out and stereo line-in". How do I disable the use of this input as a "microphone" and force it to see a "line-in?"
Posted: Mon Mar 18, 2013 5:59 pm
by IntensePC_User
Just bumping the thread.
Anyone have any ideas on how to make audio input function as a stereo line-in rather than a microphone?
Posted: Wed Mar 20, 2013 10:20 am
Please uninstall any of audio drivers, and install the one that can be found on the Compulab's website. Reboot your IntensePC and check Realteck HD Audio Manager.
Posted: Wed Mar 20, 2013 2:49 pm
by IntensePC_User
Hi gabrielh,
I've previously tried your suggestion with no luck. I've tried it again to verify.
First I removed all drivers, rebooted the PC. Next I downloaded the drivers directly from Compulab, here:
http://www.fit-pc2.com/download/Intense ... 7/drivers/
Then, Installed the downloaded driver, rebooted the PC. Updated the registry with your audio patch, rebooted the PC. I have a device attached to the line input. The following screenshots show all the information I think you'll want to see:
- Screen1.png (20.8 KiB) Viewed 24632 times
- Screen2.png (79.08 KiB) Viewed 24632 times
- Screen3.png (65.21 KiB) Viewed 24632 times
Another pic in the next post verifies the registry setting from the patch.
As you can see, it isn't showing a stereo analog input. Any suggestions?
Posted: Wed Mar 20, 2013 2:50 pm
by IntensePC_User
fourth screenshot:
- Screen4.png (64.94 KiB) Viewed 24632 times
Posted: Sun Mar 24, 2013 5:25 pm
I am unable to confirm your issue. Please make a fresh setup of Win7 x32 and install the provided audio driver. Then enter regedit utility and search for "forcedisablejd" string. Replace it's value to 01 at any locations it will be found (about 3). Restart your PC.
Posted: Mon Mar 25, 2013 8:14 pm
by IntensePC_User
Hi Gabriel,
All of my above screenshots were done from a completely clean install of Win 7 32 bit. I've now spent a many hours getting this PC set up to run properly and I'd really prefer to not lose all that work.
Can you show me equivalent screenshots from a system with a working analog stereo line-in?
Thank you.
Posted: Wed Mar 27, 2013 12:12 pm
Sure
Here is a completely clean system with a 32 bit version of Windows 7
Posted: Wed Mar 27, 2013 3:10 pm
by IntensePC_User
Thanks for posting a screenshot of your system.
It looks like you don't have a stereo line-input either, only a stereo microphone input. Any ideas on how to change that?
