Thanks to a BIOS reset, as described in the previous "BIOS Upgrade fails" thread (at: http://www.fit-pc.com/forum/viewtopic.php?f=96&t=6000), I was able to get my Intense PC to have a responsive keyboard and allow me to enter the ME_LOCK.BAT command.
The first part - the ME_UPD.BAT part of that two-part process, completely fails - reporting something akin to "unrecognized platform" (or hardware, or such). It refuses to do this update. The "LOCK" half of "ME_LOCK" seems to work, as far as it goes, but it still reports errors.
I am assuming that my Management Engine wasn't updated, but at least I can boot from the disk again.
Has anyone at fit-PC or Compulab actually tried this update on an "Intense PC" (IPC1, I guess...) and seen it work? Am I doing something wrong?
Here is the output of "/proc/cpuinfo" and "dmidecode" if that helps:
/proc/cpuinfo:
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 42
model name : Intel(R) Celeron(R) CPU 827E @ 1.40GHz
stepping : 7
microcode : 0x28
cpu MHz : 799.975
cache size : 1536 KB
physical id : 0
siblings : 1
core id : 0
cpu cores : 1
apicid : 0
initial apicid : 0
fdiv_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 13
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx rdtscp lm constant_tsc arch_perfmon pebs bts xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave lahf_lm epb tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm arat pln pts
bugs :
bogomips : 2793.57
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
# dmidecode 3.1
Getting SMBIOS data from sysfs.
SMBIOS 2.7 present.
60 structures occupying 2494 bytes.
Table at 0x000E0840.
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: CPU Socket - soldered on-board
Type: Central Processor
Family: Celeron
Manufacturer: Intel(R) Corporation
ID: A7 06 02 00 FF FB EB BF
Signature: Type 0, Family 6, Model 42, Stepping 7
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Celeron(R) CPU 827E @ 1.40GHz
Voltage: 0.9 V
External Clock: 100 MHz
Max Speed: 1400 MHz
Current Speed: 1400 MHz
Status: Populated, Enabled
Upgrade: Socket rPGA988B
L1 Cache Handle: 0x0006
L2 Cache Handle: 0x0007
L3 Cache Handle: 0x0008
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 1
Core Enabled: 1
Thread Count: 1
Characteristics:
64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Through
Installed Size: 32 kB
Maximum Size: 32 kB
Supported SRAM Types:
Unknown
Installed SRAM Type: Unknown
Speed: Unknown
Error Correction Type: Parity
System Type: Data
Associativity: 8-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Maximum Size: 32 kB
Unknown
Speed: Unknown
System Type: Instruction
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 256 kB
Maximum Size: 256 kB
Unknown
Speed: Unknown
Error Correction Type: Multi-bit ECC
System Type: Unified
Handle 0x0008, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3-Cache
Configuration: Enabled, Not Socketed, Level 3
Operational Mode: Write Back
Installed Size: 1536 kB
Maximum Size: 1536 kB
Unknown
Speed: Unknown
Associativity: 12-way Set-associative
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: Phoenix Technologies Ltd.
Version: IPC_2.2.400.3 X64
Release Date: 05/17/2017
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 3072 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
NEC PC-98
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 0.1
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: CompuLab
Product Name: Intense-PC
Version: 1.x
Serial Number: System Serial Number
UUID: ***HIDING UUID FROM THIS OUTPUT***
Wake-up Type: Other
SKU Number: System SKUNumber
Family: IPC System
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: CompuLab Ltd.
Version: 1.x
Serial Number: 1
Asset Tag: Base Board Asset Tag
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Part Component
Chassis Handle: 0x0000
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 22 bytes
Chassis Information
Type: Laptop
Lock: Not Present
Version: 1.x
Serial Number: serial#
Asset Tag: Asset Tag
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Other
Security Status: Other
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0009, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: None
Internal Connector Type: None
External Reference Designator: Keyboard
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x000A, DMI type 8, 9 bytes
External Reference Designator: Mouse
Port Type: Mouse Port
Handle 0x000B, DMI type 8, 9 bytes
Internal Connector Type: Other
External Reference Designator: COM 1
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000C, DMI type 8, 9 bytes
External Reference Designator: USB3.0 - 1#/USB2.0 - 1#
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000D, DMI type 8, 9 bytes
External Reference Designator: USB3.0 - 2#/USB2.0 - 2#
Port Type: USB
Handle 0x000E, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 3#
Port Type: USB
Handle 0x000F, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 4#
Port Type: USB
Handle 0x0010, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 5#
Port Type: USB
Handle 0x0011, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 6#
Port Type: USB
Handle 0x0012, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 7#-NOT IMPLEMENTED
Port Type: USB
Handle 0x0013, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 8#-NOT IMPLEMENTED
Port Type: USB
Handle 0x0014, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 9#--NOT IMPLEMENTED
Port Type: USB
Handle 0x0015, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 10#-mini PCIE
Port Type: USB
Handle 0x0016, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 11#
Port Type: USB
Handle 0x0017, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 12#-mini PCIE
Port Type: USB
Handle 0x0018, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 13#
Port Type: USB
Handle 0x0019, DMI type 8, 9 bytes
External Reference Designator: USB2.0 - 14#
Port Type: USB
Handle 0x001A, DMI type 8, 9 bytes
External Reference Designator: Ethernet
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x001B, DMI type 8, 9 bytes
Internal Reference Designator: SATA Port 1
Internal Connector Type: SAS/SATA Plug Receptacle
External Reference Designator: None
External Connector Type: None
Port Type: SATA
Handle 0x001C, DMI type 8, 9 bytes
Internal Reference Designator: SATA Port 2
Port Type: SATA
Handle 0x001D, DMI type 8, 9 bytes
Internal Reference Designator: SATA Port 3
Port Type: SATA
Handle 0x001E, DMI type 8, 9 bytes
External Reference Designator: eSATA Port 1
External Connector Type: SAS/SATA Plug Receptacle
Port Type: SATA
Handle 0x001F, DMI type 8, 9 bytes
External Reference Designator: eSATA Port 2
Port Type: SATA
Handle 0x0020, DMI type 8, 9 bytes
External Reference Designator: SATA Port 6
Port Type: SATA
Handle 0x0021, DMI type 9, 17 bytes
System Slot Information
Designation: PEG Gen1/Gen2/Gen3 X16
Type: x16 PCI Express
Current Usage: Available
Length: Long
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Bus Address: 0000:00:00.0
Handle 0x0022, DMI type 9, 17 bytes
Designation: PCI-Express 1 X1
Type: x1 PCI Express
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0023, DMI type 9, 17 bytes
Designation: PCI-Express 2 X1
Current Usage: In Use
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0024, DMI type 9, 17 bytes
Designation: PCI-Express 3 X1
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0025, DMI type 9, 17 bytes
Designation: PCI-Express 4 X1
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0026, DMI type 9, 17 bytes
Designation: PCI-Express 5 X4
Type: x4 PCI Express
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0027, DMI type 10, 6 bytes
On Board Device Information
Type: Video
Status: Enabled
Description: Intel(R) Extreme Graphics 3 Controller
Handle 0x0028, DMI type 10, 6 bytes
Type: Sound
Status: Enabled
Description: Intel(R) Azalia Audio Device
Handle 0x0029, DMI type 11, 5 bytes
OEM Strings
String 1: Intense-PC
Handle 0x002A, DMI type 12, 5 bytes
System Configuration Options
Handle 0x002B, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Abbreviated
Installable Languages: 7
enUS
frFR
jaJP
koKR
zhCA
zhCA
ruRU
Currently Installed Language: enUS
Handle 0x002C, DMI type 22, 26 bytes
Portable Battery
Manufacturer: None
Manufacture Date: None
Serial Number: None
Design Capacity: Unknown
Design Voltage: Unknown
SBDS Version: None
Maximum Error: Unknown
SBDS Chemistry: None
OEM-specific Information: 0x00000000
Handle 0x002D, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Handle 0x002E, DMI type 18, 23 bytes
32-bit Memory Error Information
Type: OK
Granularity: Unknown
Operation: Unknown
Vendor Syndrome: Unknown
Memory Array Address: Unknown
Device Address: Unknown
Resolution: Unknown
Handle 0x002F, DMI type 21, 7 bytes
Built-in Pointing Device
Type: Mouse
Interface: PS/2
Buttons: 2
Handle 0x0030, DMI type 23, 13 bytes
System Reset
Status: Disabled
Watchdog Timer: Present
Boot Option: Do Not Reboot
Boot Option On Limit: Do Not Reboot
Reset Count: Unknown
Reset Limit: Unknown
Timer Interval: Unknown
Timeout: Unknown
Handle 0x0031, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Unknown
Keyboard Password Status: Unknown
Administrator Password Status: Unknown
Front Panel Reset Status: Unknown
Handle 0x0032, DMI type 27, 14 bytes
Cooling Device
Type: Unknown
Status: Unknown
OEM-specific Information: 0x00000090
Nominal Speed: Unknown Or Non-rotating
Handle 0x0033, DMI type 39, 22 bytes
System Power Supply
Name: TBD by ODM
Manufacturer: TBD by ODM
Serial Number: TBD by ODM
Asset Tag: TBD by ODM
Model Part Number: TBD by ODM
Revision: 1.0
Max Power Capacity: Unknown
Status: Present, OK
Type: Battery
Input Voltage Range Switching: Other
Plugged: Yes
Hot Replaceable: Yes
Handle 0x0034, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 32 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x0035, DMI type 17, 34 bytes
Memory Device
Array Handle: 0x0034
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: ChannelA-DIMM0
Bank Locator: BANK 0
Type: DDR3
Type Detail: Synchronous
Speed: 1333 MT/s
Manufacturer: 029E
Serial Number: 00000000
Asset Tag: 9876543210
Part Number: CMSA8GX3M1A1333C9
Rank: Unknown
Configured Clock Speed: 1333 MT/s
Handle 0x0036, DMI type 17, 34 bytes
Memory Device
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: ChannelA-DIMM1
Bank Locator: BANK 1
Type: Unknown
Type Detail: None
Speed: Unknown
Manufacturer: Not Specified
Serial Number: Not Specified
Part Number: Not Specified
Rank: Unknown
Configured Clock Speed: Unknown
Handle 0x0037, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: ChannelB-DIMM0
Bank Locator: BANK 2
Type: DDR3
Speed: 1333 MT/s
Manufacturer: 029E
Rank: Unknown
Handle 0x0038, DMI type 17, 34 bytes
Memory Device
Data Width: Unknown
Form Factor: DIMM
Set: None
Locator: ChannelB-DIMM1
Bank Locator: BANK 3
Type: Unknown
Type Detail: None
Speed: Unknown
Rank: Unknown
Handle 0x0039, DMI type 19, 31 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x003FFFFFFFF
Range Size: 16 GB
Physical Array Handle: 0x0034
Partition Width: 4
Handle 0x003A, DMI type 15, 81 bytes
System Event Log
Area Length: 66 bytes
Header Start Offset: 0x0000
Header Length: 16 bytes
Data Start Offset: 0x0010
Access Method: General-purpose non-volatile data functions
Access Address: 0x00F0
Status: Valid, Not Full
Change Token: 0x00000003
Header Format: Type 1
Supported Log Type Descriptors: 29
Descriptor 1: Single-bit ECC memory error
Data Format 1: Multiple-event handle
Descriptor 2: Multi-bit ECC memory error
Data Format 2: Multiple-event handle
Descriptor 3: Parity memory error
Data Format 3: None
Descriptor 4: Bus timeout
Data Format 4: None
Descriptor 5: I/O channel block
Data Format 5: None
Descriptor 6: Software NMI
Data Format 6: None
Descriptor 7: POST memory resize
Data Format 7: None
Descriptor 8: POST error
Data Format 8: POST results bitmap
Descriptor 9: PCI parity error
Data Format 9: None
Descriptor 10: PCI system error
Data Format 10: None
Descriptor 11: CPU failure
Data Format 11: None
Descriptor 12: EISA failsafe timer timeout
Data Format 12: None
Descriptor 13: Correctable memory log disabled
Data Format 13: None
Descriptor 14: Logging disabled
Data Format 14: None
Descriptor 15: System limit exceeded
Data Format 15: None
Descriptor 16: Asynchronous hardware timer expired
Data Format 16: None
Descriptor 17: System configuration information
Data Format 17: None
Descriptor 18: Hard disk information
Data Format 18: None
Descriptor 19: System reconfigured
Data Format 19: None
Descriptor 20: Uncorrectable CPU-complex error
Data Format 20: None
Descriptor 21: Log area reset/cleared
Data Format 21: None
Descriptor 22: System boot
Data Format 22: None
Descriptor 23: OEM-specific
Data Format 23: None
Descriptor 24: OEM-specific
Data Format 24: None
Descriptor 25: OEM-specific
Data Format 25: None
Descriptor 26: OEM-specific
Data Format 26: None
Descriptor 27: OEM-specific
Data Format 27: None
Descriptor 28: OEM-specific
Data Format 28: None
Descriptor 29: OEM-specific
Data Format 29: None
Handle 0xFEFF, DMI type 127, 4 bytes
End Of Table
