Output of lspci -v
agriffis
Output of lspci -v
Post by agriffis »
Hi, could you post the output of "lspci -v" on Linux?
Re: Output of lspci -v
In what model of the IntensePC are you interested?
agriffis
Post by agriffis »
Pro please
The final version of this model is still in the factory facility. I can only post an lspci output of the prerelease model
agriffis
Post by agriffis »
That's interesting, I figured you guys already had the final version. It makes me wonder how long before my pro will arrive! (I ordered on June 5 so in theory mine should arrive in the middle of July.)
What's changing between the prelease and final? Is it major (sandy bridge vs. ivy bridge) or only minor changes?
Don't worry, You will get it on time
MrFixit
Post by MrFixit »
Could you please provide the output of an lspci -v run? I'd love to buy an IntensePC Pro, but need to confirm the used Wifi and LAN chipsets to make sure FreeBSD can run them properly (the block diagram says Intel and Realtek chips for the GigE ports, but what about WLAN and BT?)
Wlan and BT miniPCIe card can vary depends on a stock availability. We can't guarantee a particular WiFi chipset on a specific IntensePC. You can always use your favorite wlan card instead of a stock one
MrFixit
Post by MrFixit »
Sounds promising! Could you still please list the output of lspci -v? It's useful to know the exact Intel and Realtek chips, and also the sound chipset, etc.
Here is an output of an IntensePC Pro model with FM-4U4L. You can ignore the additional four intel 82583 Gigabit controlers
lspci_i7_pro_fm4u4l.zip
(1.82 KiB) Downloaded 904 times
Return to “Linux on Intense PC”
