I have installed Win7 Home Premium 64 on an IPC Business i3. I have downloaded and installed all of the Intense PC drivers from the fit-pc wiki. The device manager shows a network controller as not having a driver installed. Is there a driver that is specifically for the Business i3? Please advise on how to rectify the issue.
Thank You
Business i3 drivers
Re: Business i3 drivers
No, all Intense PC models use the same drivers as the peripherals are the same. I would suggest to re-install the drivers for the Ethernet controller again. Please make sure that you install the correct driver.
Note that Intense PC incorporates two different LAN devices requires different drivers, LAN1 is Intel and LAN2 is Realtek. Please make sure that you install both.
http://www.fit-pc.com/wiki/index.php/In ... 7#Ethernet
Return to “Windows on Intense PC”
