Will the mini PCIe slot support Msata SSD drives?
thanks,
MSATA
Re: MSATA
It's a big deal to me because I would like to use a 32-64GB Msata drive to install the OS and use the 2.5" drive bay for a large 750GB-1TB drive for media storage. A 1TB SSD is around $3000, a 1TB HD is around $150. The idea is to not have to have an external HD because space/clutter is an issue for me. I looked into the Seagate hybrid drive but it won't work because it's 9.7MM thick and the Fit PC3/Intense-PC only support 9.5MM drives.
Re: MSATA
Will a 9.7MM HD fit in the Intense PC? Do you plan on adding msata support in future versions of the Intense PC? Will it require a motherboard revision or can it be done with a BIOS update? I've been following the Fit-PC3 forums and there is suppose to be a new v2.3 motherboard with msata support. I would prefer to purchase the Intense PC over the Fit-PC3.
Re: MSATA
To: gabrielh
I have sent mail to you for order cancelling(sales@compulab.co.il)
But, I have no reply, yet.
I want to know the result for order cancelling.
