WiFi on fit-pc2!!
tamir
Re: WiFi on fit-pc2!!
Post by tamir »
When the Wifi module is not working, does LSPCI command lists the WiFi module as well ?
This might be some sort of Kernel issue, I'd suggest to try alternate between different Kernel versions.
Does older versions of Mint are more stable ?
Please try to follow the guide at our WiKi to install mint 13:
http://fit-pc.com/wiki/index.php?title= ... on_fit-PC2
Return to “Linux on fit-PC2”
