The disks - are they SSD?
Are the disks with which the fit-pc3 is fitted SSD or normal spinning hard drives? Will there be an option for SSD if not?
Re: The disks - are they SSD?
The 250GB is standard 5400 RPM spinning hard disk.
We will offer SSD in the future.
Will you offer options of fit-PC3 compatible SSD (SLC, MLC, different OEMs and performance capabilities)? Will you offer the option to install customer requested/supplied fit-PC3 compatible SSD?
As you are surely well aware, SSD may further reduce the power requirements while further increasing the speed, durability, and reliability of the fit-PC3.
We will be offering fit-PC3 models with pre-installed SSD.
There is an option for the buyer to order without a hard disk and install any SSD.
