Ubuntu [lubuntu] / no sound over HDMI
ThatTallGuy
Post by ThatTallGuy »
I've installed lubuntu 12.10 on my fit-pc3 and cannot get any sound over the HDMI port.
I see that the device is recognized -- aplay seems to work correctly (with -D hwplug:1,0) although no sound is heard.
Alsamixer reports all output values at 100% and unmuted. (Yes the TV volume is up high.)
Any suggestions?
--t
ThatTallGuy
Re: Ubuntu [lubuntu] / no sound over HDMI
More data, if it helps:
tdb@silent:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: SB [HDA ATI SB], device 0: ALC888 Analog [ALC888 Analog]
Subdevices: 1/1
card 1: SB [HDA ATI SB], device 1: ALC888 Digital [ALC888 Digital]
Subdevices: 1/1
tdb@silent:~$
ThatTallGuy
OK, revised question. Also a continuing document of where I am for future readers with the same problem.
First, thanks to this page (http://superuser.com/questions/53957/wh ... ich-to-use) I've learned about sound device aliases, which is good because after I posted the above I found that the command I had previously used didn't work anymore...
But the following command consistently succeeds:
aplay -D plughw:CARD=Generic,DEV=3 <soundfile>
Which alias to use I determined by looking at the list of aliases given by aplay -L :
tdb@silent:~$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
pulse
    PulseAudio Sound Server
hdmi:CARD=Generic,DEV=0
    HD-Audio Generic, HDMI 0
    HDMI Audio Output
dmix:CARD=Generic,DEV=3
    Direct sample mixing device
dsnoop:CARD=Generic,DEV=3
    Direct sample snooping device
    Direct hardware device without any conversions
    Hardware device with all software conversions
default:CARD=SB
    HDA ATI SB, ALC888 Analog
    Default Audio Device
... and so on and so on...
And experimenting with each of the ones that showed HDMI in the paragraph.
So the resulting question is:
How do I incorporate the information that I *always* want any sound-generating program to use "plughw:CARD=Generic,DEV=3" as the sound device into an .asoundrc file?
To enable HDMI output on Ubuntu 12.10, try to install pavucontrol
sudo apt-get install pavucontrol
and select appropriate profile under the Configuration tab.
Don't forget to reboot your system
ThatTallGuy
gabrielh wrote:To enable HDMI output on Ubuntu 12.10, try to install pavucontrol
Is pulseaudio required for HDMI audio? I don't currently have it running.
The pavucontrol will install all the necessary HDMI related libraries
ThatTallGuy
gabrielh wrote:The pavucontrol will install all the necessary HDMI related libraries
I have installed pavucontrol and it has not changed anything.
Previously, I could run
aplay -D plughw:CARD=Generic,DEV=3 /usr/share/sounds/alsa/Front_Center.wav
And I got sound just fine, but other things didn't play because HDMI wasn't the default sound device. Now, after installing pavucontrol.... I still get sound with that command, and it's still not the default sound device. Trying to run pavucontrol gives me a message "Connection to PulseAudio failed."
I just want to tell alsa to use HDMI. How to do that?
You should choose one of the HDMI profiles in the Configuration tab
Return to “Linux on fit-PC3”
