Grub loose timer
Posted: Mon Nov 07, 2011 4:12 pm
I just noticed a strange behavior, mayber not fully related to fit-pc (Ubuntu Server installed).
From time to time after a hard reboot (power cut) grub looses its timer so the fit-pc is stuck as grub menu until a key is pressed.
What is pretty strange is that it does not happen all the time. I suspect it may be caused when power cut happen during boot.
Any ideas how to make this not happen ? Remove timer and force boot to a specific image (but I might loose grub auto configuration when updating to new kernel ?).
Comments/suggestions are welcomed.
I can copy/past grub configuration if necessary, but this is default Ubuntu configuration. From tests I made it appears to happen with various Ubuntu Server versions.
Regards,
F.
Regards,
F.
