Hi, There is BIOS setting for different OS. XP, Vista, Other,
What exactly change in each setting, to best suit for the OS?
I also notice when install not successful, some time by disable the Audio, sometime the splash screen helps. But Why?
For example when install Windows 7.
Should I use the Windows Vista or use Other?
How about Linux? Again the question go back to the begining, What exactly changed in each of the option.
BIOS setting option for Windows 7
Re: BIOS setting option for Windows 7
These are settings supplied by Phoenix - the BIOS vendor - mostly subtle changes in ACPI settings inquired by OS mostly during installation.
The audio disable is an issue with Windows 7 installer and is not related to these settings.
