I have already an "old" IPC I7 pro and a new fitlet XA10-lan.
Really happy with it. But what I miss is a stack-able aluminium enclosure (for IPC/Fit-pc/fitlet) with the same form-factor (to put 2.5 hdd) or small electronic card (arduino or home made one.).
I could print it in ABS, but the problem is that plastic is non heat conductive as aluminium.
Have you already thought about it ?
Regards
Same form-factor case/enclosure.
Re: Same form-factor case/enclosure.
I would suggest relying on the universal VESA mounting for such stackable solution.
You will want several "floors" , each housing a computer or other electronics. The floors should be 60mm apart to allow airflow for the computers.
Each floor can be made of aluminum or steel plate, but you could even use plywood.
- Each plate is about 25x20 cm
- You drill 4 holes 4.5mm in the corners of 10 cm square for the VESA bracket.
- You drill 4 holes in the corners of the plate for spacers.
- Then you stack the floors with male/female spacers.
It is not common enough to make it a product, but it is quite an easy DIY.
Yes a DIY is really simple to be done. A nicer one and efficient (with temperature in mind) is little harder.
But a same form/dimension extrusion aluminium profile could be less ugly![Very Happy :-D](./images/smilies/icon_e_biggrin.gif)
And how much space do you recommend between two Fitlet XA-10 (60mm as you have said, or it's a generic "space" ?) ?
I would suggest an air-gap of 30mm or more.And how much space do you recommend between two Fitlet XA-10 (60mm as you have said, or it's a generic "space" ?) ?
