Hi Irads,
Just fired up my new fitPC2i compulab sent me as a replacement for a recent RMA.
Seems good apart from there being no analog audio. Using speakers and headphones that work when plugged into my old desktop XP PC I get no sounds out.
When I go to Control Panel, Sounds, Playback,
under:
Speakers, it tells me "High definition audio device not plugged in" with a nasty little red downwards arrow
But below that it shows:
Digital Audio (S/PDIF) High definition audio device, Default Device with a big green tick beside it.
I've been and enabled the speakers several times but nothing changes.
The microphone appears to work.
I hope you can help me,
Regards
Gunjar
No audio in win7
Re: No audio in win7
Hi Irad,
Followed those instructions, but no change. Ran the files twice, both times amongst the little black screens that flashed up momentarily there was one which seemed to be saying access denied but it was gone again before I could see the rest of the little white print.
When I go to control panel, speakers, properties, it shows
controler information
Jack information
LR with green jack symbol,rear panel 3.5mm jack
C sub with pink jack symbol rear panel 3.5mm jack
RLR with black jack symbol rear panel 3.5mm jack
LR with grean jack symbol front panel 3.5mm jack
instead of the two jacks that are really there on the rear panel of the fitPC2i
So still no sound where to from here
Regards
Gunjar
Jack information
Regards
Gunjar
Open the audio_patch.exe file from from command line (CMD).
It will allow you to see the output of the application.
Leonid Firdman
Thanks Leonid,
BUT how do you get to the command line?
When I go to open the audio_patch.exe file I'm only offered 'Run as Administrator'
When I open it from there a small black box (DOS?) opens and briefly shows:
' Error Access denied' then too quickly for me to copy it, something about device disabled & then device enabled. then the box disapears.
Then when I go to 'Sounds' in the control panel the speakers are still shown as disconnected.
It also offers running from 'troubleshoot compatability' I've tried running it from there, get the same little black window also telling me 'Error access denied' then Devcon.exe is not recognised as an internal, external operable command or batchfile, then similar stuff about audio device enabling.
But still there is no change and no sound.
I'm sorry but I'm not very 'Tech' savvy so you will have to explain things in words of one sylable or nearby.
Gunjar
Gunjar
Hi Leonid,
Further to yesterday's message, trying again to find some way to make this thing work, found I could copy some of the text coming up in the DOS box, some but not all, if I wait too long to copy it, the box just disapears again - - -
<ERROR: Access is denied.
HDAUDIO\FUNC_01&VEN_10EC&DEV_0662&SUBSYS_10EC0662&REV_1001\4&34DB6129&0&0001: Disabled
1 device(s) disabled.
Audio device enabling
HDAUDIO\FUNC_1&VEN_10EC7DEV_0662 . . . . . . . . . . .>
can never get to copy the last part it flashes away to fast
I hope that helps.
The ability to have sound functions is an important part of having a PC for me. So please let me know what further there is to do.
Regards
Gunjar
I hope that helps.
Regards
Gunjar
Hi.
Please, download the attached audio_patch.zip file. Unzip the audio_patch.exe file.
Run it in Administrator mode (right click on the file and choose the Run as administrator option).
Verify that the CMD output is same to the attached screenshot CMDout.pg
- CMDout.jpg (53.78 KiB) Viewed 15102 times
- audio_patch.zip
- (35.24 KiB) Downloaded 648 times
Leonid Firdman
Hi Leonid,
OK so now I know what a CMD output is, Ta, thats what I've been calling a little black box or DOS box.
And as I said in the last email I'm not getting the display you show, and having run it again from todays attachment I'm still getting the same thing:
HDAUDIO\FUNC_1&VEN_10EC7DEV_0662 . . . etc
I don't know how to do a screen shot so I've just copied and pasted as much as I could get of it.
Where to from here
Regards
Gunjar
Where to from here
Regards
Gunjar
Hi.
Did you use Run as administrator option when you run the file from today's attachment?
Leonid Firdman
Hi Leonid,
I sure did.
Gunjar
I sure did.
Gunjar
