Corrupt graphics on lucid when resizing windows?
raldi
Post by raldi »
I've got a fit-pc2 that I'd like to use as a desktop machine. I installed Ubuntu Lucid (desktop version) on it, and then followed the instructions at:
http://www.fit-pc2.com/wiki/index.php/I ... buntu_9.10
...substituting "lucid" for "karmic" where applicable. (In other words, I installed the packages at http://fit-pc2.com/download/ubuntu/dists/lucid/binary/)
Things seem to mostly work, except whenever I resize a window, it gets all corrupt, like this:
http://imgur.com/oJQbO
Sometimes that causes the whole machine to get locked up... sometimes it doesn't.
Is this a known issue? Is there a workaround?
Re: Corrupt graphics on lucid when resizing windows?
Hello
Please set visual effects to "none"
raldi
Post by raldi »
Thanks, that seems to have fixed the problem. Do you know what particular visual effect causes the problem? I'd prefer to just disable that one, rather than put everything in low-effects mode.
To enable the visual effects please install Ubuntu 10.10/LinuxMint 10 from their official LiveCD and use our itc repository to install kernel and graphic drivers:
- Add the following lines to /etc/apt/sources.list
deb http://compulab.co.il/workspace/sw/itc/maverick binary/
deb-src http://compulab.co.il/workspace/sw/itc/maverick source/
- Refresh update manager
sudo apt-get update
- Install kernel image, kernel headers, graphic drivers and media player for HD playback:
sudo apt-get install linux-image-2.6.38-34-itc linux-headers-2.6.38-34-itc xserver-xorg-video-emgd mplayer-vaapi mplayer-skins
- Remove generic image and sources that are not fully compatible with fit-PC2.
sudo apt-get purge linux-generic linux-image-generic linux-headers-generic linux-image-$(uname -r) linux-headers-$(uname -r) && sudo apt-get autoremove
- Restart fit-PC2
Return to “Ubuntu 10.04”
