headless ubuntu 10.04
petesinc
Post by petesinc »
Hi, Ubuntu 10.04 is running fine, after following instructions to update the kernel. However I need to run my fit-pc2 without a screen (and without vnc). The boot process fails at some point if I don't attach a screen. If I then attach a screen its blank.
I tried all the work arounds on the ubuntu forum: http://ubuntuforums.org/showthread.php?t=1452600&page=5 but none of these seem to work does anyone have a solution?
remlog
Re: headless ubuntu 10.04
Post by remlog »
did you solved the problem to headless operation of the fit-pc2i?
thank you very much
Return to “Ubuntu 10.04”
