Should DRI work?
Koen
Should DRI work?
Post by Koen »
I have a question with a Lucid 10.04 install: should DRI work in combination with the FitPC repo? My kernel is 2.6.35-34-fitpc2 #2 SMP Thu Dec 30 14:36:27 IST 2010 i686 GNU/Linux.
The middle section that caught my eye was this:
(II) [drm] DRM interface version 1.0
(EE) [drm] Could not set DRM device bus ID.
(II) EMGD(0): [dri] DRIScreenInit failed. Disabling DRI.
(II) EMGD(0): First stage of DRI initialization failed (disabled).
(II) EMGD(0): [DRI2] Setup complete
(II) EMGD(0): DRI2 initialization complete.
Here's the full X.org log:
X.Org X Server 1.7.6
Release Date: 2010-03-17
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-28-server i686 Ubuntu
Current Operating System: Linux muis 2.6.35-34-fitpc2 #2 SMP Thu Dec 30 14:36:27 IST 2010 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.35-34-fitpc2 root=UUID=d0abd54e-5c30-4390-8908-8e4eebeadb02 ro splash quiet
Build Date: 10 November 2010  11:25:26AM
xorg-server 2:1.7.6-2ubuntu7.4 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.16.4
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Jan  4 15:10:17 2011
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/usr/lib/X11/xorg.conf.d"
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Card0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) Option "DontZap" "false"
(**) Option "IgnoreABI" "true"
(**) Option "GlxVisuals" "all"
(**) Ignoring ABI Version
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
        Entry deleted from font path.
(==) FontPath set to:
        /usr/share/fonts/X11/misc,
        /usr/share/fonts/X11/100dpi/:unscaled,
        /usr/share/fonts/X11/75dpi/:unscaled,
        /usr/share/fonts/X11/Type1,
        /usr/share/fonts/X11/100dpi,
        /usr/share/fonts/X11/75dpi,
        /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
        built-ins
(==) ModulePath set to "/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
(**) Extension "Composite" is enabled
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Mouse0
(WW) Disabling Keyboard0
(II) Loader magic: 0x81f1b20
(II) Module ABI versions:
        X.Org ANSI C Emulation: 0.4
        X.Org Video Driver: 6.0
        X.Org XInput driver : 7.0
        X.Org Server Extension : 2.0
(++) using VT number 7
(--) PCI:*(0:0:2:0) 8086:8108:8086:8119 Intel Corporation System Controller Hub (SCH Poulsbo) Graphics Controller rev 7, Mem @ 0xb0080000/524288, 0xc0000000/268435456, 0xb0000000/262144, I/O @ 0x00001810/8
(II) Open ACPI successful (/var/run/acpid.socket)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
        compiled for 1.7.6, module version = 1.0.0
        Module class: X.Org Server Extension
        ABI class: X.Org Server Extension, version 2.0
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
        compiled for 1.7.6, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
        compiled for 1.7.6, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "emgd"
(II) Loading /usr/lib/xorg/modules/drivers/emgd_drv.so
(II) Module emgd: vendor="Intel(R) Corporation"
        compiled for 1.7.99, module version = 1.5.1742
        Module class: X.Org Video Driver
        ABI class: X.Org Video Driver, version 7.0
(WW) module ABI major version (7) doesn't match the server's version (6)
(II) EMGD: Intel(R) Embedded Media and Graphics Driver version 1.5.1742 for:
        Intel US15W Class
(II) Primary Device is: PCI 00@00:02:0
(II) EMGD(0): Creating default Display subsection in Screen section
        "Screen0" for depth/fbbpp 24/32
(==) EMGD(0): RGB weight 888
(==) EMGD(0): Default visual is TrueColor
drmOpenDevice: node name is /dev/dri/card0
drmOpenByBusid: Searching for BusID PCI:00:00:00
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: drmOpenMinor returns 9
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
drmOpenDevice: node name is /dev/dri/card1
drmOpenByBusid: drmOpenMinor returns -1
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
drmOpenDevice: node name is /dev/dri/card15
drmGetBusid returned ''
(II) EMGD(0): Chipset: "Intel SCH US15 Chipset"
(II) EMGD(0): Checking for new style options
(II) EMGD(0): Processing version 7.0 options
(II) EMGD(0): Using configuration 1
(II) EMGD(0): Checking for US15 specific configuration.
(II) EMGD(0): Checking for non-chipset specific configuration.
(II) EMGD(0): Setting port_order to 20000
(II) EMGD(0): Option processing done!
(II) EMGD(0): Valid Display Configurations:
(II) EMGD(0):   DC: 0x00000021
(II) EMGD(0):   DC: 0x00400022
(II) EMGD(0):   DC: 0x00400028
(II) EMGD(0):   DC: 0x00000041
(II) EMGD(0):   DC: 0x00000000
(II) EMGD(0): Using Display Configuration 0x00000021
(**) EMGD(0): Depth 24, (--) framebuffer bpp 32
(==) EMGD(0): Using gamma correction (1.0, 1.0, 1.0)
(II) EMGD(0): 8 modes passed validation checks
(--) EMGD(0): Virtual size is 1920x1080 (pitch 0)
(**) EMGD(0):  Built-in mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 28.1 kHz, 25.0 Hz (I)
(II) EMGD(0): Modeline "1920x1080"x25.0   74.25  1920 2447 2491 2639  1080 1082 1092 1123 interlace +hsync +vsync (28.1 kHz)
(**) EMGD(0):  Built-in mode "1280x720": 74.2 MHz (scaled from 0.0 MHz), 37.5 kHz, 50.0 Hz
(II) EMGD(0): Modeline "1280x720"x50.0   74.25  1280 1719 1759 1979  720 724 729 749 +hsync +vsync (37.5 kHz)
(**) EMGD(0):  Built-in mode "720x576": 27.0 MHz (scaled from 0.0 MHz), 31.3 kHz, 50.0 Hz
(II) EMGD(0): Modeline "720x576"x50.0   27.00  720 731 795 863  576 580 585 624 (31.3 kHz)
(**) EMGD(0):  Built-in mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 33.8 kHz, 30.0 Hz (I)
(II) EMGD(0): Modeline "1920x1080"x30.0   74.25  1920 2007 2051 2199  1080 1082 1092 1123 interlace +hsync +vsync (33.8 kHz)
(**) EMGD(0):  Built-in mode "1280x720": 74.2 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz
(II) EMGD(0): Modeline "1280x720"x60.0   74.25  1280 1389 1429 1649  720 724 729 749 +hsync +vsync (45.0 kHz)
(**) EMGD(0):  Built-in mode "720x480": 27.0 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) EMGD(0): Modeline "720x480"x60.0   27.00  720 735 797 857  480 488 494 524 (31.5 kHz)
(**) EMGD(0):  Built-in mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) EMGD(0): Modeline "640x480"x60.0   25.18  640 647 743 799  480 481 483 524 (31.5 kHz)
(**) EMGD(0):  Built-in mode "1280x768": 68.2 MHz (scaled from 0.0 MHz), 47.4 kHz, 60.0 Hz
(II) EMGD(0): Modeline "1280x768"x60.0   68.25  1280 1327 1359 1439  768 770 777 789 (47.4 kHz)
(==) EMGD(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
        ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(II) EMGD(0): General Driver Configuration Options
(II) EMGD(0):   PCF Version:            7.00
(II) EMGD(0):   Configuration ID:       1
(II) EMGD(0): Primary Display Configuration Options
(II) EMGD(0):   VideoRam (Pixmap Cache): 32768
(II) EMGD(0):   PORT AND DISPLAY OPTIONS
(II) EMGD(0):     Port Order:           20000
(II) EMGD(0):     Display Config:       Single
(II) EMGD(0):     Display Detect:       On
(II) EMGD(0):     FB Blend Overlay:     Off
(II) EMGD(0):     Gang DVO:             Off
(II) EMGD(0):     Clone Width:          0
(II) EMGD(0):     Clone Height:         0
(II) EMGD(0):     Clone Refresh:        0
(II) EMGD(0):   FRAMEBUFFER OPTIONS
(II) EMGD(0):     Shadow FB:            Off
(II) EMGD(0):     Tear FB:              On
(II) EMGD(0):     Resize:               Off
(II) EMGD(0):   FRAMEBUFFER ORIENTATION OPTIONS
(II) EMGD(0):     Rotation:             0 degrees
(II) EMGD(0):     Flip:                 Off
(II) EMGD(0):   HARDWARE ACCELERATION OPTIONS
(II) EMGD(0):     HW 2D Accel:          On
(II) EMGD(0):     HW Cursor:            On
(II) EMGD(0):   XVIDEO OPTIONS
(II) EMGD(0):     XVideo:               On
(II) EMGD(0):     XVideoBlend:          Off
(II) EMGD(0):     XVideoMC:             Off
(II) EMGD(0):     XVideoKey:            0xff00ff00
(II) EMGD(0):     Overlay Gamma Red:    0x100
(II) EMGD(0):     Overlay Gamma Green:  0x100
(II) EMGD(0):     Overlay Gamma Blue:   0x100
(II) EMGD(0):     Overlay Brightness:   0x8000
(II) EMGD(0):     Overlay Contrast:     0x8000
(II) EMGD(0):     Overlay Saturation:   0x8000
(II) EMGD(0):     DRI:                  On
(II) EMGD(0):     DRI2:                 On
(II) EMGD(0):     EDID:                 On
(II) EMGD(0):   QUICKBOOT OPTIONS
(II) EMGD(0):     QuickBoot:            0
(II) EMGD(0):     Seamless:             Off
(II) EMGD(0):     Video Input:          0
(II) EMGD(0):     Splash Screen:        Off
(II) EMGD(0):    INTERRUPT OPTIONS
(II) EMGD(0):      Polling:             Off
(II) EMGD(0):   GLOBAL PER PORT OPTIONS
(II) EMGD(0):   Port 2            DVI
(II) EMGD(0):      Multi-DVO:      Off
(II) EMGD(0):      Centering:      Off
(II) EMGD(0):      RenderScale:    Off
(II) EMGD(0):      EDID Avail:     0x2
(II) EMGD(0):      EDID Not Avail: 0x1
(II) EMGD(0):      PANEL INFORMATION
(II) EMGD(0):         FP width:     0
(II) EMGD(0):         FP height:    0
(II) EMGD(0):         BKLT Enable:  0
(II) EMGD(0):         BKLT Method:  1
(II) EMGD(0):         BKLT T1:      60
(II) EMGD(0):         BKLT T2:      200
(II) EMGD(0):         BKLT T3:      200
(II) EMGD(0):         BKLT T4:      50
(II) EMGD(0):         BKLT T5:      400
(II) EMGD(0):         GPIO Pin VDD: 0
(II) EMGD(0):         GPIO Pin VEE: 0
(II) EMGD(0):         GPIO Pin BKLT:0
(II) EMGD(0):         DVO i2c pin:  0
(II) EMGD(0):         DVO i2c DAB:  0
(II) EMGD(0):         DVO i2c speed:0
(II) EMGD(0):         DVO ddc pin:  0
(II) EMGD(0):         DVO ddc speed:0
(II) EMGD(0):      Number DTD's:   0
(II) EMGD(0):      Number Attr's:  0
(II) EMGD(0):   Port 4            (null)
(II) EMGD(0):      EDID Avail:     0x3
(II) EMGD(0):      EDID Not Avail: 0x5
(II) EMGD(0):         BKLT Method:  0
(II) EMGD(0):         BKLT T1:      0
(II) EMGD(0):         BKLT T2:      0
(II) EMGD(0):         BKLT T3:      0
(II) EMGD(0):         BKLT T4:      0
(II) EMGD(0):         BKLT T5:      0
(==) Depth 24 pixmap format is 32 bpp
drmOpenDevice: open result is 10, (OK)
drmOpenByBusid: Searching for BusID PCI:00:02:00
drmOpenByBusid: drmOpenMinor returns 10
drmOpenDevice: open result is 11, (OK)
drmOpenByBusid: drmOpenMinor returns 11
drmOpenDevice: open result is 12, (OK)
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenByBusid: drmOpenMinor returns 12
[/b]
(II) UXA(0): Driver registered support for the following operations:
(II)         solid
(II)         copy
(II)         composite (RENDER acceleration)
(II) EMGD(0): Video acceleration initialization complete
(==) EMGD(0): Backing store disabled
(II) EMGD(0): Hardware Cursor Initialization complete.
(==) EMGD(0): Silken mouse enabled
(==) EMGD(0): DPMS enabled
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
drmOpenDevice: open result is 13, (OK)
drmOpenByBusid: drmOpenMinor returns 13
(II) AIGLX: enabled GLX_MESA_copy_sub_buffer
(II) AIGLX: enabled GLX_SGI_make_current_read
(II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
(II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
(II) AIGLX: Loaded and initialized /usr/lib/dri/emgd_dri.so
(II) GLX: Initialized DRI2 GL provider for screen 0
(II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
(II) config/udev: Adding input device Video Bus (/dev/input/event3)
(**) Video Bus: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
        compiled for 1.7.6, module version = 2.3.2
        Module class: X.Org XInput Driver
        ABI class: X.Org XInput driver, version 7.0
(**) Video Bus: always reports core events
(**) Video Bus: Device: "/dev/input/event3"
(II) Video Bus: Found keys
(II) Video Bus: Configuring as keyboard
(II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD)
(**) Option "xkb_rules" "evdev"
(**) Option "xkb_model" "pc105"
(**) Option "xkb_layout" "us"
(**) Option "xkb_options" "lv3:ralt_switch"
(II) XKB: reuse xkmfile /var/lib/xkb/server-0C76CA335E924C2441A31FBFED02D59A89874CA6.xkm
(II) config/udev: Adding input device Power Button (/dev/input/event0)
(**) Power Button: Applying InputClass "evdev keyboard catchall"
(**) Power Button: always reports core events
(**) Power Button: Device: "/dev/input/event0"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
(II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event4)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device Wireless Keyboard/Mouse (/dev/input/event1)
(**) Wireless Keyboard/Mouse: Applying InputClass "evdev keyboard catchall"
(**) Wireless Keyboard/Mouse: always reports core events
(**) Wireless Keyboard/Mouse: Device: "/dev/input/event1"
(II) Wireless Keyboard/Mouse: Found keys
(II) Wireless Keyboard/Mouse: Configuring as keyboard
(II) XINPUT: Adding extended input device "Wireless Keyboard/Mouse" (type: KEYBOARD)
(II) config/udev: Adding input device Wireless Keyboard/Mouse (/dev/input/event2)
(**) Wireless Keyboard/Mouse: Applying InputClass "evdev pointer catchall"
(**) Wireless Keyboard/Mouse: Device: "/dev/input/event2"
(II) Wireless Keyboard/Mouse: Found 8 mouse buttons
(II) Wireless Keyboard/Mouse: Found scroll wheel(s)
(II) Wireless Keyboard/Mouse: Found relative axes
(II) Wireless Keyboard/Mouse: Found x and y relative axes
(II) Wireless Keyboard/Mouse: Found absolute axes
(II) Wireless Keyboard/Mouse: Configuring as mouse
(**) Wireless Keyboard/Mouse: YAxisMapping: buttons 4 and 5
(**) Wireless Keyboard/Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) Wireless Keyboard/Mouse: initialized for relative axes.
(WW) Wireless Keyboard/Mouse: ignoring absolute axes.
(II) config/udev: Adding input device Wireless Keyboard/Mouse (/dev/input/mouse0)
drmOpenDevice: open result is 25, (OK)
drmOpenByBusid: drmOpenMinor returns 25
Return to “Ubuntu 10.04”
