BIOS update 23-Dec-09 released with overclocking support
Locked
To get the BIOS update check http://www.fit-pc2.com/wiki/index.php?title=BIOS_Update
BIOS update is safe on all fit-PC2. Update is not necessary.
The most significant change is support for overclocking.
Warning: Overclocking is for advanced users only. It is not guaranteed to work on every unit due to variance in manufacturing of CPU and other components. Overclocking may result in system instability, loss of data, system device malfunction and overheating.
For a complete list of changes check
http://www.fit-pc2.com/wiki/index.php?t ... 3-Dec-2009
Flying-Dutchman
Re: BIOS update 23-Dec-09 released with overclocking support
Post by Flying-Dutchman »
Added support for ALC662 codec
Added support for ALC262 audio codec
Is there a new APU in the Fit-PC's? (on the forum it said ALC260)
http://209.85.229.132/search?q=cache:Ir ... clnk&gl=nl
Sad that the 192Khz and Audio DVD support would then be gone... Personally i'm not that into 5.1.
Added support for overclocking
Added support for spread spectrum control
Sweet about the overclocking support. Is the voltage also changable (for expl. for undervolting)?
ALC662 may be used in the future. CompuLab will announce when it does.
Voltage control is not supported independently in BIOS.
Flying-Dutchman
irads wrote:Voltage control is not supported independently in BIOS.
Is that a hardware limitation or is it an BIOS limitation?
Is anybody having any luck with undervolting the atom Z530 or adjusting the Intel EIST?
Locked
Return to “BIOS updates fit-PC2”
