hdmi display issue : working with a monitor and not with a v
Philippe
Post by Philippe »
I bought a fit pc2 recently and installed windows 7 on it. I installed all the drivers downloaded from fit pc site.
When I connect to my DVI monitor, it works fine. So fit PC HW is probably fine.
When I connect it to my video projector (want to use it as a media server and home theater), I do not have any image, although :
- the projector is recognised (I see it in the list of displays with the proper name)
- I set a resolution and frequency compatible with the video projector
- the cable is good
Any idea of what I can do ? Is it because my video projector is HDMI (and not DVI ?, I am not a specialist sorry) ?
Do you think that installing Windows XP instead of Windows 7, it could work better ?
Should I also try to install an older version of the drivers provided for windows 7, or just wait for a newer release of them ?
Thanks for any help
Phiilippe
Re: hdmi display issue : working with a monitor and not with
Hello
Did you tested your projector on another Windows 7 machine?
Philippe
Post by Philippe »
Thanks for taking care of my problem.
Yes, I tried my video projector on another computer using same version of Windows 7 (ultimate) and it works fine.
However, it is of course not using the same video card, my laptop (fujitsu siemens amilo) uses a Nvidia graphic board & driver
Best regards
Philippe
We will update our drivers and I'll post them for you. I will PM you when they'll be ready
Philippe
Post by Philippe »
Thanks. Do you need any information from my projector to update the driver ?
Philippe
Philippe
Post by Philippe »
Hello Gabriel,
Any idea whaen the new driver should be ready ?
Philippe
Hello Philippe
Our software engineer is still working on this driver.
Philippe
Post by Philippe »
Hello Gabriel,
Thanks for this info and your support.
Do you have any idea when this new driver should be posted ?
Best regards
Philippe
Hello
The driver was sent via email
