No Video after Windows install starts
ChicagoTS
Post by ChicagoTS »
Just got my Fit-PC2i from Amazon today.. very excited. Had it delivered to a trade show I'm at. I wanted to run a small webserver off it at the show for registration.
I plugged it into a Samsung 22inch monitor running at 1600x1050 and when the unit booted for the first time, the bios window came up and then a starting windows display. After a few moments, the screen goes black and then the monitor light starts flashing (no signal). After 5 minutes, I turned off the unit and turned it back on. I tried to boot into Safe Mode but it said it needed to complete setup and could not do that in safe mode.
I'm assuming it doesn't like the monitor resolution for some reason. Any way I can get this running?
benjgil
Re: No Video after Windows install starts
Post by benjgil »
Booting initially in VGA mode should let you see the video output past the splash screen - Press F8 on startup.
Once you've gone through setup you can set the resolution output to the one your monitor is looking for - generally 1280 x 768 works for most monitors, though the best resolution to use is always the monitor's native resolution.
Hope that helps!
Benjamin
You need to enable LCD clock in BIOS.
fit-PC forum admin
ChicagoTS
Post by ChicagoTS »
Where can I find that? I don't see that in the BIOS.
Phoenix BIOS Date 8/31/09
MENU OPTIONS - Main / Advanced / Intel / Security / Boot / Exit
In Intel there is a Video sub menu but it only shows memory allocation.
BIOS from 31-Aug-09 does not have control over LCD clock - it is always enabled. Are you sure you have fit-PC2i and not fit-PC2 ?.
fit-PC forum admin
ChicagoTS
Post by ChicagoTS »
DOH! I was telling someone about the "i" model and must have typed that.
Sorry. Yes, PC2 (not i)
ChicagoTS
Post by ChicagoTS »
Got back from my trip and plugged into another monitor with a more normal (standard) res and it came up. But.. it only sees 1024x768 as the max. Also I see that it thinks there are 2 displays?
Disable display 1 (LVDS, not connected) - then you should have all supported resolutions on display 2 (SDVO).
fit-PC forum admin
