Hi there,
since 2 days im trying to get my wlan working under ubuntu. I always get
the same error : "authentication on ap timed out". I can see the
network, but i cant connect. Tried WPA, WEP.
So here is my story :
Started 9.04 LiveCD from USB. Wlan works.
Installed 9.04 on another USB and bootet the new installation. Wlan works.
Installed "Kernel related stuff" and the other drivers. Wlan timed out.
Replaced the Gnomestuff against Wicd. Wlan timed out.
Started 8.04 LTS from USB. No Wlan.
Installed 8.04 on another USB and bootet the new installation. No Wlan.
Installed "Kernel related stuff" and the other drivers. Now wlan exists,
but timed out.
I have no idea whats wrong. In both cases i have used the install
instructions from the wiki.
Anyone can help ?
Thanks in advance.
Andre
Ubuntu no WLAN
Re: Ubuntu no WLAN
Its me again. Made some steps forward. I know now that wlan stops after replacing the xorg.conf and reboot. If i replace the "fitpc2-xorg.conf" against the original, wlan works for me (after another boot).
Have no ideo why. Hope this helps someone to explain the problem to me.
Re: Ubuntu no WLAN
What type of wi-fi card do you have? Post output of
lspci | grep -i network
Re: Ubuntu no WLAN
Hi Denis,
this command gives no output. I found a manual to start wlan by commandline. Here is the result :
Maybe this helps ?
Another question: Is it possible to get a complete 9.04 installation (incl. all drivers and of course wlan) as ISO-Image ?
Andre
sudo wpa_supplicant -Dwext -iwlan0 -c/etc/wpa_supplicant.conf -dd
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'wext' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ap_scan=1
ctrl_interface='/var/run/wpa_supplicant'
Line: 4 - start of a new network block
ssid - hexdump_ascii(len=5):
72 65 61 70 31 reap1
scan_ssid=0 (0x0)
proto: 0x1
key_mgmt: 0x2
PSK (ASCII passphrase) - hexdump_ascii(len=16): [REMOVED]
pairwise: 0x8
group: 0x8
PSK (from passphrase) - hexdump(len=32): [REMOVED]
Priority group 0
id=0 ssid='reap1'
Initializing interface (2) 'wlan0'
Interface wlan0 set UP - waiting a second for the driver to complete initialization
SIOCGIWRANGE: WE(compiled)=22 WE(source)=21 enc_capa=0xf
capabilities: key_mgmt 0xf enc 0xf flags 0x0
WEXT: Operstate: linkmode=1, operstate=5
Own MAC address: 00:12:0e:ad:c3:27
wpa_driver_wext_set_wpa
wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_countermeasures
wpa_driver_wext_set_drop_unencrypted
RSN: flushing PMKID list in the driver
Setting scan request: 0 sec 100000 usec
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
Added interface wlan0
Ignore event for foreign ifindex 3
RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
Wireless event: cmd=0x8b06 len=8
State: DISCONNECTED -> SCANNING
Starting AP scan (broadcast SSID)
Trying to get current scan results first without requesting a new scan to speed up initial association
Received 0 bytes of scan results (0 BSSes)
Cached scan results are empty - not posting
Selecting BSS from priority group 0
Try to find WPA-enabled AP
Try to find non-WPA AP
No suitable AP found.
Setting scan request: 0 sec 0 usec
Scan requested (ret=0) - scan timeout 5 seconds
EAPOL: disable timer tick
Wireless event: cmd=0x8b19 len=8
CTRL-EVENT-SCAN-RESULTS
Setting scan request: 5 sec 0 usec
Scan requested (ret=0) - scan timeout 30 seconds
Received 312 bytes of scan results (1 BSSes)
0: 00:12:17:69:45:8c ssid='reap1' wpa_ie_len=22 rsn_ie_len=0 caps=0x11
selected based on WPA IE
selected WPA AP 00:12:17:69:45:8c ssid='reap1'
Trying to associate with 00:12:17:69:45:8c (SSID='reap1' freq=2472 MHz)
Cancelling scan request
WPA: clearing own WPA/RSN IE
Automatic auth_alg selection: 0x1
WPA: using IEEE 802.11i/D3.0
WPA: Selected cipher suites: group 8 pairwise 8 key_mgmt 2 proto 1
WPA: set AP WPA IE - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
WPA: clearing AP RSN IE
WPA: using GTK TKIP
WPA: using PTK TKIP
WPA: using KEY_MGMT WPA-PSK
WPA: not using MGMT group cipher
WPA: Set own WPA IE default - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
No keys have been configured - skip key clearing
State: SCANNING -> ASSOCIATING
wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
WEXT: Operstate: linkmode=-1, operstate=5
wpa_driver_wext_associate
wpa_driver_wext_set_psk
Setting authentication timeout: 10 sec 0 usec
EAPOL: External notification - EAP success=0
EAPOL: External notification - EAP fail=0
EAPOL: External notification - portControl=Auto
Wireless event: cmd=0x8b04 len=12
Authentication with 00:12:17:69:45:8c timed out.
Added BSSID 00:12:17:69:45:8c into blacklist
State: ASSOCIATING -> DISCONNECTED
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
WPA: using GTK TKIP
WPA: using PTK TKIP
^CCTRL-EVENT-TERMINATING - signal 2 received
Removing interface wlan0
Removed BSSID 00:12:17:69:45:8c from blacklist (clear)
Cancelling authentication timeout
WEXT: Operstate: linkmode=0, operstate=6
reese@robi:~$
Andre
Re: Ubuntu no WLAN
No, I do not know about manual you have used. It does not help too much.
First, let`s find out type of wi-fi card you have. Post output of lspci, iwconfig, ifconfig.
Re: Ubuntu no WLAN
Hi Denis,
because in the future i dont want to run x locally, i removed the display driver and the xorg.conf and tried to configure the wlan without network-manager or wicd from commandline. I used wpa_supplicant. The situation is now: i can connect via wpa_supplicant startet from x-terminal, but i cant connect started from tty01 (commandline). In both cases i use exactly the same commands.
Here are the outputs from wpa_supplicant :
TTY01(WLAN is not working)
X-Terminal (WLAN is working)
Here are the outputs you asked for :
Thank you,
Andre
ap_scan=1
key_mgmt: 0x2
proto: 0x1
pairwise: 0x8
group: 0x8
Priority group 0
id=0 ssid='reap1'
Failed to get scan results
Failed to get scan results - try scanning again
Received 311 bytes of scan results (1 BSSes)
WPA: using GTK TKIP
WPA: using PTK TKIP
WPA: using GTK TKIP
WPA: using PTK TKIP
ap_scan=1
key_mgmt: 0x2
proto: 0x1
pairwise: 0x8
group: 0x8
Priority group 0
id=0 ssid='reap1'
WPA: using GTK TKIP
WPA: using PTK TKIP
Already associated with the selected AP.
Wireless event: cmd=0x8c02 len=175
WEXT: Custom wireless event: 'ASSOCINFO(ReqIEs=00057265617031010802040b160c12182432043048606cdd160050f20101000050f20201000050f20201000050f202 RespIEs=010882848b962430486c32040c121860dd050010180100)'
Association info event
req_ies - hexdump(len=47): 00 05 72 65 61 70 31 01 08 02 04 0b 16 0c 12 18 24 32 04 30 48 60 6c dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
resp_ies - hexdump(len=23): 01 08 82 84 8b 96 24 30 48 6c 32 04 0c 12 18 60 dd 05 00 10 18 01 00
WPA: set own WPA/RSN IE - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
RTM_NEWLINK: operstate=0 ifi_flags=0x11003 ([UP][LOWER_UP])
Wireless event: cmd=0x8b15 len=20
Wireless event: new AP: 00:12:17:69:45:8c
State: ASSOCIATING -> ASSOCIATED
Associated to a new BSS: BSSID=00:12:17:69:45:8c
Associated with 00:12:17:69:45:8c
WPA: Association event - clear replay counter
WPA: Clear old PTK
EAPOL: External notification - portEnabled=1
EAPOL: SUPP_PAE entering state CONNECTING
EAPOL: enable timer tick
EAPOL: SUPP_BE entering state IDLE
RX EAPOL from 00:12:17:69:45:8c
RX EAPOL - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 00 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 53 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IEEE 802.1X RX: version=1 type=3 length=95
EAPOL-Key type=254
key_info 0x89 (ver=1 keyidx=0 rsvd=0 Pairwise Ack)
key_length=32 key_data_length=0
replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 00
key_nonce - hexdump(len=32): 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 53 ff ff
key_iv - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
key_rsc - hexdump(len=8): 00 00 00 00 00 00 00 00
key_id (reserved) - hexdump(len=8): 00 00 00 00 00 00 00 00
key_mic - hexdump(len=16): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
WPA: RX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 00 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 53 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
State: ASSOCIATED -> 4WAY_HANDSHAKE
WPA: RX message 1 of 4-Way Handshake from 00:12:17:69:45:8c (ver=1)
WPA: Renewed SNonce - hexdump(len=32): dc bb cf ba c1 70 d3 8b 8d 4a c6 f9 37 64 c2 59 17 3d 57 9c b3 97 da d2 98 2e d0 5e c3 f3 0f 8e
WPA: PTK derivation - A1=00:12:0e:ad:c3:27 A2=00:12:17:69:45:8c
WPA: PMK - hexdump(len=32): [REMOVED]
WPA: PTK - hexdump(len=64): [REMOVED]
WPA: WPA IE for msg 2/4 - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
WPA: Sending EAPOL-Key 2/4
WPA: TX EAPOL-Key - hexdump(len=123): 01 03 00 77 fe 01 09 00 20 00 00 00 00 00 00 00 00 dc bb cf ba c1 70 d3 8b 8d 4a c6 f9 37 64 c2 59 17 3d 57 9c b3 97 da d2 98 2e d0 5e c3 f3 0f 8e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 72 15 a1 b6 5d ef 85 f1 80 9f 14 49 25 56 a1 b2 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
RX EAPOL - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 01 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 53 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EAPOL-Key type=254
replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 01
WPA: RX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 00 89 00 20 00 00 00 00 00 00 00 01 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 53 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
State: 4WAY_HANDSHAKE -> 4WAY_HANDSHAKE
WPA: TX EAPOL-Key - hexdump(len=123): 01 03 00 77 fe 01 09 00 20 00 00 00 00 00 00 00 01 dc bb cf ba c1 70 d3 8b 8d 4a c6 f9 37 64 c2 59 17 3d 57 9c b3 97 da d2 98 2e d0 5e c3 f3 0f 8e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 86 62 47 a6 5b 2a 98 33 9c a5 06 ef 57 bc c8 58 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
RX EAPOL - hexdump(len=123): 01 03 00 77 fe 01 c9 00 20 00 00 00 00 00 00 00 02 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 53 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ac b2 2c 4d 65 3d a7 95 c7 bd e3 9b da 54 19 09 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
IEEE 802.1X RX: version=1 type=3 length=119
EAPOL-Key type=254
key_info 0x1c9 (ver=1 keyidx=0 rsvd=0 Pairwise Install Ack MIC)
key_length=32 key_data_length=24
replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 02
key_mic - hexdump(len=16): ac b2 2c 4d 65 3d a7 95 c7 bd e3 9b da 54 19 09
WPA: RX EAPOL-Key - hexdump(len=123): 01 03 00 77 fe 01 c9 00 20 00 00 00 00 00 00 00 02 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 53 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ac b2 2c 4d 65 3d a7 95 c7 bd e3 9b da 54 19 09 00 18 dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
WPA: RX message 3 of 4-Way Handshake from 00:12:17:69:45:8c (ver=1)
WPA: IE KeyData - hexdump(len=24): dd 16 00 50 f2 01 01 00 00 50 f2 02 01 00 00 50 f2 02 01 00 00 50 f2 02
WPA: Sending EAPOL-Key 4/4
WPA: TX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 01 09 00 20 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 da 1f 73 c4 1e ac f0 16 55 52 c2 61 71 a9 0d 0a 00 00
WPA: Installing PTK to the driver.
WPA: RSC - hexdump(len=6): 00 00 00 00 00 00
wpa_driver_wext_set_key: alg=2 key_idx=0 set_tx=1 seq_len=6 key_len=32
State: 4WAY_HANDSHAKE -> GROUP_HANDSHAKE
RX EAPOL - hexdump(len=131): 01 03 00 7f fe 03 91 00 20 00 00 00 00 00 00 00 03 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 51 ff ff af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 54 ff ff 0d 2e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7e 83 dc 16 a4 43 57 3e d0 49 90 19 e5 50 09 c4 00 20 47 ac b0 d7 0d 06 d4 01 b9 58 05 5b 2e d0 57 49 87 46 a1 68 af d3 d8 bf 82 34 8e ad 56 e6 44 5c
IEEE 802.1X RX: version=1 type=3 length=127
EAPOL-Key type=254
key_info 0x391 (ver=1 keyidx=1 rsvd=0 Group Ack MIC Secure)
key_length=32 key_data_length=32
replay_counter - hexdump(len=8): 00 00 00 00 00 00 00 03
key_nonce - hexdump(len=32): 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 51 ff ff
key_iv - hexdump(len=16): af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 54 ff ff
key_rsc - hexdump(len=8): 0d 2e 00 00 00 00 00 00
key_mic - hexdump(len=16): 7e 83 dc 16 a4 43 57 3e d0 49 90 19 e5 50 09 c4
WPA: RX EAPOL-Key - hexdump(len=131): 01 03 00 7f fe 03 91 00 20 00 00 00 00 00 00 00 03 14 f2 d3 1a e3 9b 1d f3 85 14 92 2f 14 35 c5 7b af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 51 ff ff af 9d ee 40 7c 0f 5a ac ee 44 a4 f2 c1 54 ff ff 0d 2e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7e 83 dc 16 a4 43 57 3e d0 49 90 19 e5 50 09 c4 00 20 47 ac b0 d7 0d 06 d4 01 b9 58 05 5b 2e d0 57 49 87 46 a1 68 af d3 d8 bf 82 34 8e ad 56 e6 44 5c
WPA: RX message 1 of Group Key Handshake from 00:12:17:69:45:8c (ver=1)
State: GROUP_HANDSHAKE -> GROUP_HANDSHAKE
WPA: Group Key - hexdump(len=32): [REMOVED]
WPA: Installing GTK to the driver (keyidx=1 tx=0 len=32).
WPA: RSC - hexdump(len=6): 0d 2e 00 00 00 00
wpa_driver_wext_set_key: alg=2 key_idx=1 set_tx=0 seq_len=6 key_len=32
WPA: Sending EAPOL-Key 2/2
WPA: TX EAPOL-Key - hexdump(len=99): 01 03 00 5f fe 03 11 00 20 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0c 95 bf f2 23 03 d7 34 2c cd 93 80 61 30 f9 92 00 00
WPA: Key negotiation completed with 00:12:17:69:45:8c [PTK=TKIP GTK=TKIP]
State: GROUP_HANDSHAKE -> COMPLETED
CTRL-EVENT-CONNECTED - Connection to 00:12:17:69:45:8c completed (auth) [id=0 id_str=]
wpa_driver_wext_set_operstate: operstate 0->1 (UP)
WEXT: Operstate: linkmode=-1, operstate=6
EAPOL: External notification - portValid=1
EAPOL: External notification - EAP success=1
EAPOL: SUPP_PAE entering state AUTHENTICATING
EAPOL: SUPP_BE entering state SUCCESS
EAPOL: SUPP_PAE entering state AUTHENTICATED
EAPOL authentication completed successfully
RTM_NEWLINK: operstate=1 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
EAPOL: startWhen --> 0
State: COMPLETED -> DISCONNECTED
wpa_driver_wext_set_operstate: operstate 1->0 (DORMANT)
wpa_driver_wext_deauthenticate
ioctl[SIOCSIWENCODEEXT]: No such file or directory
Driver did not support SIOCSIWENCODEEXT
reese@robi:~$ lspci
00:00.0 Host bridge: Intel Corporation System Controller Hub (SCH Poulsbo) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation System Controller Hub (SCH Poulsbo) Graphics Controller (rev 07)
00:1b.0 Audio device: Intel Corporation System Controller Hub (SCH Poulsbo) HD Audio Controller (rev 07)
00:1c.0 PCI bridge: Intel Corporation System Controller Hub (SCH Poulsbo) PCI Express Port 1 (rev 07)
00:1d.0 USB Controller: Intel Corporation System Controller Hub (SCH Poulsbo) USB UHCI #1 (rev 07)
00:1d.1 USB Controller: Intel Corporation System Controller Hub (SCH Poulsbo) USB UHCI #2 (rev 07)
00:1d.2 USB Controller: Intel Corporation System Controller Hub (SCH Poulsbo) USB UHCI #3 (rev 07)
00:1d.7 USB Controller: Intel Corporation System Controller Hub (SCH Poulsbo) USB EHCI #1 (rev 07)
00:1e.0 SD Host controller: Intel Corporation System Controller Hub (SCH Poulsbo) SDIO Controller #1 (rev 07)
00:1e.1 SD Host controller: Intel Corporation System Controller Hub (SCH Poulsbo) SDIO Controller #2 (rev 07)
00:1f.0 ISA bridge: Intel Corporation System Controller Hub (SCH Poulsbo) LPC Bridge (rev 07)
00:1f.1 IDE interface: Intel Corporation System Controller Hub (SCH Poulsbo) IDE Controller (rev 07)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 02)
reese@robi:~$ lshw -C network
WARNING: you should run this program as super-user.
*-network
description: Ethernet interface
product: RTL8111/8168B PCI Express Gigabit Ethernet controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: eth0
version: 02
serial: 00:01:c0:05:e3:8f
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical
configuration: broadcast=yes driver=r8169 driverversion=2.3LK-NAPI ip=192.168.0.19 latency=0 module=r8169 multicast=yes
*-network:0 DISABLED
description: Wireless interface
physical id: 1
logical name: wlan0
serial: 00:12:0e:ad:c3:27
capabilities: ethernet physical wireless
configuration: broadcast=yes multicast=yes wireless=IEEE 802.11bg
*-network:1 DISABLED
physical id: 2
logical name: pan0
serial: 9e:f0:0e:10:5b:34
configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A multicast=yes
reese@robi:~$ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11bg ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=0 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
pan0 no wireless extensions.
reese@robi:~$ ifconfig
eth0 Link encap:Ethernet Hardware Adresse 00:01:c0:05:e3:8f
inet Adresse:192.168.0.19 Bcast:192.168.0.255 Maske:255.255.255.0
inet6-Adresse: fe80::201:c0ff:fe05:e38f/64 Gültigkeitsbereich:Verbindung
UP BROADCAST RUNNING MULTICAST MTU:1500 Metrik:1
RX packets:3834 errors:0 dropped:0 overruns:0 frame:0
TX packets:2920 errors:0 dropped:0 overruns:0 carrier:0
Kollisionen:0 Sendewarteschlangenlänge:1000
RX bytes:292331 (292.3 KB) TX bytes:374439 (374.4 KB)
Interrupt:7 Basisadresse:0x8000
lo Link encap:Lokale Schleife
inet Adresse:127.0.0.1 Maske:255.0.0.0
inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine
UP LOOPBACK RUNNING MTU:16436 Metrik:1
RX packets:130 errors:0 dropped:0 overruns:0 frame:0
TX packets:130 errors:0 dropped:0 overruns:0 carrier:0
Kollisionen:0 Sendewarteschlangenlänge:0
RX bytes:20058 (20.0 KB) TX bytes:20058 (20.0 KB)
Andre
