Ubuntu 9.10 supported
Denis
Post by Denis »
Hi all,
Ubuntu 9.10 is officially supported. There are new graphic drivers available (beta version) - IEGD Intel® Embedded Graphics Drivers.
Prepare installation media
- You can use USB CD-ROM Drive or USB Flash drive (disk-on-key) as installation media.
- Download Ubuntu 9.10 Desktop installation
- If you are using USB CD-ROM - burn downloaded image directly on CD.
-If you are using USB Flash drive, 1GB would be enough. Download usb-creator to create bootable installation flash drive.
Installation of generic Ubuntu 9.10 Desktop
- Standard Ubuntu installation - choose timezone, partitions, username, password etc.
- Unplug USB CD-ROM / USB Flash drive and reboot
- Login using previously selected username and password
Required system changes
- Add the following lines to /etc/apt/sources.list
deb http://fit-pc2.com/download/ubuntu/dists/karmic binary/
deb-src http://fit-pc2.com/download/ubuntu/dists/karmic source/
- Refresh update manager
sudo apt-get update
- Install kernel image, kernel headers, graphic drivers and media player for HD playback:
sudo apt-get install linux-image-2.6.31-34-fitpc2 linux-headers-2.6.31-34-fitpc2 xserver-xorg-video-poulsbo mplayer-vaapi mplayer-skins
- Comment out snd-hda-intel options in /etc/modprobe.d/alsa-base.conf
# Power down HDA controllers after 10 idle seconds
# options snd-hda-intel power_save=10 power_save_controller=N
- Remove generic image and sources that are not fully compatible with fit-PC2.
sudo apt-get purge linux-generic linux-image-generic linux-headers-generic linux-image-$(uname -r) linux-headers-$(uname -r) && sudo apt-get autoremove
- Restart fit-PC2
Ubuntu 9.10 is now installed.
Known issues:
- Suspend and Hibernate functions do not work properly and disabled in kernel. Using these functions is equal to Lock Screen.
nixarn
Re: Ubuntu 9.10 supported
Post by nixarn »
That is awesome! I'm gonna try it out right away!
Thanks!
Niklas
blegas78
Post by blegas78 »
Great! I'll have to do this as soon as I have some free time!
nixarn
Post by nixarn »
Just wanted to let you know it works great!
Thanks a lot!
Niklas
Mylife
Post by Mylife »
Thank you Denis !
morgad
Post by morgad »
Can you upgrade in-place from 8.04lts to 9.10 on the fit-pc, or do you need to do full re-install?
Dave
arie
Post by arie »
It worked for me. Took a long time however..
Mylife
Post by Mylife »
The best would be to do a full re-install (and take advantage of the "ext4" filsesystem).
It won't take a long time to do it (while an upgrade is never 100% secure and, as mentionned in arie's post, it's slow).
When doing a full re-install, you can avoid formating your /home partition (if your home is not on the same partition as the root filesystem) and reuse it (but you'll keep an "ext3" filesystem on it though).
morgad
Post by morgad »
my FitPC2 came with only one partition - they did not put /home on a separate one :-(
Think I will wait till I get the SSD drive and install 9.04 on that :-) That way if it all goes wrong I can just plug the old hard disc back in.
Dave
prj
Post by prj »
Nice! How about the new graphics driver? Any faster/slower than previously?
Return to “Ubuntu 9.10”
