wow...
thanks for the update!
That was sad to see after that pretty previous screenshot of Q3..
Atleast one positive thing, it supports OpenGL 2 in FurMark (the app atleast starts it seems). But there is still much to fix in the drivers...
Weird that disabling HT causes glitches in Q3
Well i'm sorry that i'm not much use (now), but im looking forward to the new release IF it comes with OpenGL updates and/or add's DirectX 9.0c...
Still, i'm looking forward to buy the Fit-PC-2i... i need that dual ethernet and low power consumption combo . I hope I can find a way to mod the drivers in the future when I can test;).
Thanks again
OpenGL (apps,games) failed
Re: OpenGL apps(games) failed
google earth (last iegd drivers 10.3 ,2 feb 2010) windows xp on 1024x768 opengl
- google_earth.JPG (180.83 KiB) Viewed 13986 times
Re: OpenGL (apps,games) failed
Same config plus 1080p. Gashiss, sorry. C'pas normal !
Still, it is (a bit) slow
- opengl_google_earth.IEGD103.winxpsp3.1080p.JPG (106.42 KiB) Viewed 13976 times
just noticed it worked on higher definitions but doesn't on 800x600 or 1024,
maybe that 's the result of hd fury adapter
Hey all.
Have there been any changes in performance with the Fit-PC2 and Open GL ... Currently I'm holding back to see if this device will fit my needs.
My needs, General office use (which should be fine) with the occasional gaming.
Roller Coaster Tycoon 3, War craft 1,2,3, Star Craft, Open Arena, Warzone 2100 ..
Some of which run in GL ... Has anyone tested Direct x ?
I can say I played warcraft 1 with dosbox without problems,
I don't own the other games, I could test for open arena if you want cause
it's free.
it's free.
Hey gashiss
It would be great if you could test out Open Arena, and Warzone 2100
( openarena.ws ) & ( wz2100.net )
Open Arena uses the Quake engine, which I recall there being problems with, and don't know what version of OpenGL Warzone 2100.
Thank you for all your help.
My needs are tossed between a Fit-Pc2, and a Acer Revo 3610..
W.
W.
yes, open arena also uses an updated version of the id tech 3 engine, so a benchmark/screenshot would be great!
I tested open arena, it works smoothly on 640x480, but as soon as I change the resolution it crashes,giving this error:
C:\DOCUME~1\collao\LOCALS~1\Temp\WERdbde.dir00\Mini050210-01.dmp
C:\DOCUME~1\collao\LOCALS~1\Temp\WERdbde.dir00\sysdata.xml
pretty common on this forum.
