The new gma500 driver
Display driver and X11
Dominik
Re: The new gma500 driver
Post by Dominik »
I'm only using fbdev in xorg! I tried out proprietary drivers a couple of time ago (e.g. emgd), but all of them weren't stable enough and scrolling in x-terminals was horrible slow!
But with uvesafb and the new psb_gfx (which I had to blacklist if I want to use uvesafb anymore), I cannot see any difference in x11-handling (scrolling, moving windows, etc). And framerate at glxgears are exactly the same (116-120 fps).
Indeed, I had to use grub/915resolution to set my lcd hw-resolution for uvesafb.
prj
Post by prj »
Dominik wrote:I'm only using fbdev in xorg! I tried out proprietary drivers a couple of time ago (e.g. emgd), but all of them weren't stable enough and scrolling in x-terminals was horrible slow!
You're right, uvesafb has linear memory (as of VBE 2.0) so the performance should be equal to that of psb_gfx.
prj
Post by prj »
Here is a status update of what's going on in drm-next:
- Console framebuffer defaults to 16bpp which resulted in the resolution limit to be lifted.
- The modesetting driver has matured so running 1920x1080 at 32bpp works fine
- Hardware cursor support is on it's way (I have it working on my end) but I need to fix it up a bit before it goes into drm-next. Until then you can specify:
Option "swcursor" "1"
in the device section of your xorg.conf to get a visible cursor.
Patrik
Return to “Display driver”
