FitPC2i input voltage range
bsi
Post by bsi »
I am planning to supply power to a fit PC2i. My options are as follows:
- Lithium-Ion 14.8 nominal: will go from 16V down to ~ 12.5 V as it discharges.
- SLA: 12V nominal, will go from ~ 13V to 11.5 through discharge
Can the FitPC2i be powered with the above options? What is its DC input operating range please?
Thx
L.
Re: FitPC2i input voltage range
The input voltage range is 10-15Vdc. See online specs:
http://www.fit-pc.com/web/products/spec ... 2G-C1600-W
Return to “Power and Heat”
