FItPC has no power until re-plug Power adapter
kevin
Post by kevin »
We have 20 some FitPC2i units with original power adpater.
Running FitPCs for a couple of weeks then turning them off through OS, we could not power them on again by pressing power button in front.
Unpluged power adapter from power outlet then pluged in, the FitPC powered on as normal.
Please advice if this is by design or an issue we should fix.
Thanks and regards
Kevin
Re: FItPC has no power until re-plug Power adapter
I am not familiar with that problem. If you experience it on multiple units we can assume this is not a specific HW problem. Does the power LED stay dark when you press the power button or does it light and the system does not boot?
Which OS are you using and is it pre-installed by CompuLab or a custom installation?
Return to “Power and Heat”
