Hi, I noticed that while running heavy applications, e.g. Antivirus scan, my fit-PC2 2GB/2GHz Win7 Pro 250GB HD temperature can rise to over 50 degrees at room temperature, and the surface casing is scalding to touch.
I'm using Core Temp to measure temperature - see attached screen capture.
Is this temperature going to break my fit-PC? If I don't wish to install an external heatsink, what can I do to ensure fit-PC does not overheat?
Appreciate for any tip, thanks.
fit-PC2 2GB/2GHz Win7 Pro temperature rises to 52C?
- temp.JPG (35.91 KiB) Viewed 10713 times
Re: fit-PC2 2GB/2GHz Win7 Pro temperature rises to 52C?
FitPC2 works fine at such temperature, it will not break ti
gabrielh wrote:FitPC2 works fine at such temperature, it will not break ti
Thanks for replying. Do you mean 50+ Degree Celsius is ok?
Yes
gabrielh wrote:Yes
Thank you.
