ssd performance?
littlehuman
ssd performance?
Post by littlehuman »
I am planning to use ocz vertex with fit pc 2. Am I going to get full performance of vertex with fit pc 2?
p.s: ah.. how do I cancel my order? I contact sales@fit-pc.com serveral times. He/she does not reply...I re-ordered fit-pc2 diskless instead of fit-pc2 value wifi...
ender
Re: ssd performance?
Post by ender »
Fit-PC2 has only IDE interface, and an IDE->SATA bridge, so you won't be able to get full performance from Vertex. But then again, if you really want a superfast machine, you wouldn't be going for Fit-PC2 anyway.
Work week in Israel is Sunday through Thursday. It may take 2-3 business days to process order cancellation.
Brain
Post by Brain »
Ok, too bad it doesn't perform for the full 100%.
But it does mean that SSD's will work in the FIT-PC? I'm not really interessed in hardcore performance but in ultra-low power consumption for my little fileserver.
and as all the attached computers are two laptops ( wireless ) harddisk performance of the fileserver is not that important for me.
SATA SSD works well with fit-PC2. The most noticeable effect is the absolute silence.
SaWey
Post by SaWey »
I equipped my fit pc with a 30Gb OCZ Vertex SSD and it's running great in absolute silence.
siliconlunch
Post by siliconlunch »
I just installed a 50GB OCZ Vertex 2 SATA II 2.5" SSD (OCZSSD2-2VTX50G) into my Fit-PC2. It uses MLC NAND with the SandForce 1200 controller.
Early impressions are that it has made the machine only marginally faster. hdparm -t, also, reports only about 60MB/sec max IO throughput to the SSD. For those unfamiliar with hdparm, it's a Linux tool that measures raw sustained, sequential data read performance, bypassing any filesystem overheads.
The drive is spec'd at 285MB/s (max) and I have seen this model perform around this level for sequential reads in a regular PC.
Is there anything one can optimize (BIOS, etc) to improve the IO? Seems the SATA architecture is the bottleneck?
BTW, I am going to do the same hdparm tests with my original 2.5" HDD and compare to see the difference.
yogev_ezra
Post by yogev_ezra »
FitPC2 uses PATA->SATA Marvell bridge chip as the US15W chipset does not natively support SATA. Therefore the speed would be limited to 100 MB/sec PATA throughput. However the figure you presented (same as for regular HDD) is too low anyway, I would expect something in range of 70-90 MB/sec.
To test the real SSD speed on FitPC2 I would recommend you to install Windows and use some tool like CrystalDiskMark.
siliconlunch
I'm in the process of installing karmic, to see if any of the Fit-PC2 drivers make a difference.
I had installed Lucid initially on the SSD.
siliconlunch
After installing karmic I ran hdparm tests again.
The average over 10 tests performed on a freshly booted quiescent system comes out to around 55 MB/sec.
This is certainly disappointing considering the theoretical max disk throughput is 100 MB/sec.
Anyone hazard a guess as to what the issue might be? Driver? SSD? Kernel?
Return to “Storage”
