E-SATA hardware support for port multiplier
spindrift_21
Post by spindrift_21 »
I need a quick answer on whether the Fit-PC2 E-SATA port supports port multiplier devices such as the Thermaltake BlacX Duet seen here:
http://www.thermaltakeusa.com/Product.a ... 46&ID=1895
If you don't know that answer, but can tell me what chipset the Fit-PC2 has I may be able to figure it out.
Thanks!
yogev_ezra
Re: E-SATA hardware support for port multiplier
Post by yogev_ezra »
Fit-PC2 does not have E-SATA port. It has one SATA port that is implemented over IDE bus, so if you want to connect an external hard disk to it, better to use USB port.
Return to “Storage”
