No audio from audio jack in the front
quangkevin
Post by quangkevin »
I'm having trouble getting audio from audio jack in the face module to work on Ubuntu.
Any advice is greatly appreciated.
Thanks!
tamir
Re: No audio from audio jack in the front
Post by tamir »
Hi, do you get Audio output from the back ?
Please provide the machine's S/N as printed on the white label located inside the side panel clamshell door.
quangkevin
Hi Tamir,
Yes, audio output from the back works.
S/N: 1190806-00104
tamir
Post by tamir »
Thank you.
Our R&D are investigating this issue.
Will return asap.
tamir
Post by tamir »
Sorry for this taking long time, we are still investigating.
Will update as soon as possible.
quangkevin
Thanks for the update
tamir
Post by tamir »
The following commands can switch between rear and front audio codecs on Linux.
Tested with the current BIOS version (0.29.x) and Linux Mint 19.2.
Instructions:
First install alsa tools:
         sudo apt install alsa-tools
To enable the front codec:
        sudo hda-verb /dev/snd/hwC0D0 0x14 0x71f 0x41
        sudo hda-verb /dev/snd/hwC0D0 0x18 0x71f 0x41
        pulseaudio -k & sleep 1 & sudo alsa force-reload
Now the front codec should work and the rear codec is disabled until next reset.
To switch back to the rear codec, the user can either restart or run this:
      sudo hda-verb /dev/snd/hwC0D0 0x14 0x71f 0x01
      sudo hda-verb /dev/snd/hwC0D0 0x18 0x71f 0x01
The upcoming BIOS release will include a menu item for switching between rear and front codecs on Linux.
Return to “Airtop3 Hardware”
