fit-statUSB: 1st Impressions
Posted: Mon Aug 06, 2018 2:11 am
by hassellbear
fit-statUSB is a brand new, very cool and colorful offering from the technology innovators at Compulab. It is a tiny USB RGB led indicator that can display almost any color imaginable with selectable brightness. It can also fade from one color to the next with selectable timing, and it can blink on/off. It is comparable in function to the ThingM Blink1 device, but fit-statUSB is superior in that it is less than half the price, significantly smaller, and easier to program.
Controlling and Programming
fit-statUSB emulates a serial device and is controlled/programmed using simple text commands sent via the serial port. It truly is easy to control and program using a terminal program or any programming language which supports serial port communications. The output color is selected by sending the hex value which corresponds to the desired color such as #FF0000/red, #00FF00/green, or #0000FF/blue. Controlling it couldn't be easier.
Controlling Using Minicom Terminal Emulator in Linux Mint
Controlling fit-statUSB.png (30.41 KiB) Viewed 19157 times
Corresponding Red - Green - Blue Output
As the above picture shows, fit-statUSB can be quite bright for its small size, but its brightness can easily be reduced via commands.
fit-statUSB is a really cool device that is easy to control and program. Since it costs little more than 2 premium coffees at the local coffee house, it is well within the means of almost everyone.
Further Information
For further product information and technical data see:
https://fit-iot.com/web/product/fit-statusb/
http://fit-pc.com/wiki/index.php/Fit-statUSB
