VGA adapters
Moderator: Andrey.Mazlin
David.Blake
VGA adapters
Post by David.Blake »
I'm seeking a HDMI or DP to VGA adapter. We had several DP ones but none worked with the FitLet.
I've ordered some HDMI ones to test, but wonder if someone has already confronted & resolved this issue.
David.Blake
Re: VGA adapters + power
In my search, I have a question. Does the fitlet2 provide power on both Mini-Display-Port & the HDMI output ports?
Given I'm driving a VGA monitor, I'm not after bleeding edge, the monitor tops out of 1024x768@60Hz.
But finding an adapter that works is a bit of a snipe hunt so far. Some say they need external power. Hence my question.
David.Blake
Re: VGA adapters
We have tested the following VGA-out adapters & they function well for us.
Startech.com: MDP2VGAMM3B, MDP2VGA2
Rankie: 1080P
Andrey.Mazlin
Post by Andrey.Mazlin »
David.Blake wrote:
Fri Jan 29, 2021 12:20 am
Yes, HDMI 5V@0.5A and miniDP 3.3V@0.5A
Useful links:
https://fit-iot.com/web/
Return to “fitlet2 hardware”
