GPIO (leds) default values
Moderator: Andrey.Mazlin
paolodenti
Post by paolodenti »
I have not found any setting in the UEFI to set the default value of LED 2 and 3 to off.
How can it be done?
Thank you
tamir
Re: GPIO (leds) default values
Post by tamir »
Please find below manual for controlling the fitlet2 GPIO front LEDs:
http://fit-pc.com/wiki/index.php?title= ... front_LEDs
paolodenti
tamir wrote:Please find below manual for controlling the fitlet2 GPIO front LEDs:
thank you Tamir, we are already using the gpio to control the LEDs.
However my question was related to the default value of the LED, the one set, I guess, by the firmware.
The LEDs, after power on, are ON by default and we would like to have them OFF.
tamir
Post by tamir »
Unfortunately, it is not possible to control the default behavior from EFI.
This requires certain BIOS development as this feature is currently not available.
paolodenti
tamir wrote:Unfortunately, it is not possible to control the default behavior from EFI.
Thank you Tamir
As a personal consideration, I think the default value should always be off.
If LEDs 2 and 3 are meant to be customized by the user, they are meant to go on whenever the user service is "ready/on/available" and that happens under some explicit actions; it does not happen when the board is booting.
Mikael63
Post by Mikael63 »
After my RMA, these LED behave a little differently.
Previously, I could with a simple script (Linux) turn off the LED directly at startup, if I wanted.
These LED then remained off even at shutdown.
Now these LED are lit green which feels illogical. Yellow or off when the unit is off would have been more logical.
Andrey.Mazlin
Post by Andrey.Mazlin »
Mikael63 wrote:
Wed Mar 24, 2021 5:35 pm
Can you please check the BIOS version of this device?
Useful links:
https://fit-iot.com/web/
Mikael63
Post by Mikael63 »
Andrey.Mazlin wrote:
Mon Mar 29, 2021 8:36 am
BIOS version FLT2.MBM2.0.46.02.00
Build 01/11/2021 11:55:53
Andrey.Mazlin
See this: https://fit-pc.com/wiki/index.php?title ... 7-Mar-2021
R&D did a roll back of BIOS, so you can try to install a new version.
https://fit-pc.com/wiki/index.php?title ... IOS_Update
Useful links:
Mikael63
Post by Mikael63 »
Thu Apr 01, 2021 12:24 pm
Confirmed - works!
Thanks!
Return to “fitlet2 hardware”
