ipc3 with xen and qubes-os
alain
Post by alain »
I use one ip3 with xen and qubes-os.
bios: 0.25.08, qubes-os4, fedora29, no NetworkManager.
I have a bad behavior, after reboot, randomly, i can't ping others computer with rj45 ethernet (no wifi using)
No issues with fedora configuration as iptable, route and...
I reboot several times and the connection can raise up without conf modification. I never lose the ethernet connection until one reboot.
No error message in logs about e1000e / igb intel module, pci or other think linked to ethernet use.
Somebody would have one idea of this issue?
Thanks.
Alain
tamir
Re: ipc3 with xen and qubes-os
Post by tamir »
As much as we'd like to help, we lack the knowledge to advise regarding Xen or cubes OS.
In order to troubleshoot this issue, we suggest to test it in a supported environment such as Windows or Linux mint which are known to work.
For Linux installation please follow the guide below:
https://fit-pc.com/wiki/index.php?title ... _Mint_19.1
For Windows, please follow the below:
https://fit-pc.com/wiki/index.php?title ... _UEFI_mode
Please see if you are able to replicate the same behavior on these environments.
Return to “General IPC3 questions”
