Fitlet-X-LAN with ESXi 5.5 / 6.0 WORKING
jhonny
Post by jhonny »
Hi All,
UPDATE: 19-Aug-2015
I have been in touch with Andreas from http://www.v-front.de who recently has worked on editing the igb driver (required for I211 adapter) to make it work with ESXi.
Background information:
The NVM checksum of the firmware on the FACET card in the fitlet-x-lan reported by the igb driver as invalid. This causes the driver to not find any valid physical network interfaces.
He has recompiled the driver and disabled the checksum check.
I tested the driver and it works with: ESXi 5.5 and ESXi 6.0
Please head over to Andreas's website and give him a small donation if you appreciate his dedication and hard work.
Head over to http://www.v-front.de for the download, it should be available shortly.
The adapters also work in passthrough mode (IOMMU / VT-d)
jhonny
Re: Fitlet-X-LAN with ESXi - no LAN adapters
Post by jhonny »
This page seems to suggest it works, however after following that tutorial in the link i can say it does not:
http://www.fit-pc.com/wiki/index.php/FA ... re_ESXi.3F
We've tried to install ESXi 5.5 (and 6.0) on several systems but it found out that ESXi doesn’t support I211 Intel NICs used in the systems. We do not support officially ESXi in our systems.
However you can refer to this:
"How to add Intel NIC drivers to an ESXi 5.5 ISO"
http://blog.kihltech.com/2014/01/how-to ... i-5-5-iso/
jhonny
Post by jhonny »
The problem is those instructions don't work. They don't enable the I211 adapters in ESXi.
Did you get ESXi working at all ? Even though its not supported ?
No.
Sent from my GT-N7100 using Tapatalk
jhonny
Re: Fitlet-X-LAN with ESXi 5.5 / 6.0 WORKING
Post by jhonny »
UPDATE
Return to “Other operating systems on fitlet”
