Cannot boot
mikeFitPC
Cannot boot
Post by mikeFitPC »
My new fitlet-x-lan barbone with a 8GB RAM and m2-SSD card will not show any information on the monitor.
when I power it up with RAM and SSD card in, it only blinks green every 9 to 10 secs.
I did reset the bios via the hardware button.
When I remove the RAM, the power button blinks constantly...
The unit gets quite hot, as if it is doing something.
I switched the HDMI port already, but no signal to monitor either. HDMI cable works on other monitor.
Any idea? Can you help me in any way or do you recommend to request an RMA?
Mike
Arwen
Re: Cannot boot
Post by Arwen »
The fitlet series does not support M.2 SSDs, only mSATA. I am guessing mSATA is
what you used. If not, that could be one problem.
Next, what is the make, model, and speed of your RAM module?
Arwen Evenstar
Rivendale, Middle Earth
mikeFitPC
Re: Cannot boot
Post by mikeFitPC »
Uhh, my mistake: it is an msata.
it is this drive: Kingston HDSSD mSATA 120GB mS200
and this RAM:
Crucial 8GB DDR3L 1600 MT/s RAM ((PC3L-12800) SODIMM 204-Pin - CT102464BF160B)
Does this help?
Arwen
Re: Cannot boot
Post by Arwen »
mikeFitPC wrote:...
This should be fine.
mikeFitPC wrote:...
and this RAM:
Yes, that RAM should also be fine.
My only suggestions at present are these;
  • Re-seat or remove the FACET card, (which has the 3 x LAN ports on it).
  • Remove the mSATA drive and any other drive, (like USB). Then power up.
If none of that helps, and no one else has any suggestions, RMA it, (return it for
service or replacement).
Arwen Evenstar
Re: Cannot boot
Return to “fitlet faults and troubleshooting”
