Memtest86+ freezes
Posted: Wed Apr 29, 2015 6:28 pm
by llowrey
I am only able to run Memtest86+ (v5.01) in fail-safe mode (F1). The default and SMP modes freeze instantly.
My memory passes when I run fail-safe mode plus I've made it through 12hrs of mprime so I know the fitlet is stable.
When I use the Memtest86+ config menu to read the RAM SPD it freezes instantly. I suspect there is an issue with how SPD is read on the fitlet.
Does anyone else have this problem with Memtest86+?
Re: Memtest86+ freezes
Posted: Thu Apr 30, 2015 1:18 pm
by Arwen
I don't remember any specific trouble with Memtest86+, but the latest stable version in the Gentoo repository was 4.20-r1.
Gentoo has it's own list of stable verses un-stable for packages. Version 5.01 is listed as un-stable. I can easily try reading my RAM SPD with 4.20-r1, and if good, repeat with 5.01.
Posted: Thu Apr 30, 2015 7:08 pm
We expect to issue a BIOS revision in the near future. I will pass the SPD observation to the BIOS team.
Posted: Fri May 01, 2015 12:23 am
by Arwen
I was never able to get Memtest86+ version 5.01 to work with my fitlet-iA10, simply
blank screen. Trying F1 did nothing.
Using 4.20-r1 runs through the memory testing, though mis-identifies the SO-DIMM.
This also does not return SPD configuration, complaining about;
- SMBus Controller not known
That SMBus is probably the way memory SPD EEPROMs are read. So I am not
surprised that it mis-identified my SO-DIMM.
Posted: Sun May 03, 2015 6:16 am
This is the answer from Compulab BIOS team:
The fitlet's BIOS supports the RAM SPD.
Memtest86+ is not supported by the AMD Mullins SOC
http://www.memtest.org/#change
We recommend the commercial version of the Passmark Memtest86 Pro.
http://www.memtest86.com/
