Power consumption and EMC
bibo01
Post by bibo01 »
I would like to use a fitlet in text mode exclusively, ethernet input and USB output only. A few more hardware questions:
7) What is the power consumption/voltage?
8) Do ethernet and usb have separate channels?
9) How many layers is the mainboard? Does ground have separate layer?
10) Did you measure emi/rf? How does it compare to Fit-PC2?
Re: Hardware questions
7) Power consumption is very dependent on workload. 5W is a reasonable assumption.
8) Yes. Please consult block diagram.
9) The PCB is over 8 layers. There are multiple ground layers.
10) EMC testing is underway. fitlet meets CE mark class B and is comparable to fit-PC2 in low radiated emission.
bibo01
Post by bibo01 »
Thanks for your reply. All very interesting.
7) At what voltage/ampere?
7) 12V, ~0.4A
alpha_one_x86
Re: Power consumption and EMC
Post by alpha_one_x86 »
So hight, in what condition? Ethernet? With usb?
My project for do file copy: http://ultracopier.first-world.info/
Return to “Memory”
