Low voltage DDR support
oelewap
Post by oelewap »
- does it support low voltage DDR (1,35V) so-dimm?
- do you have a list of certified memory?
Re: Hardware questions
Low voltage DDR3 may be supported. It is BIOS dependent. We will issue a list of tested DDR3 models.
iroha
Re: Low voltage DDR support
Post by iroha »
AMD's web site says the processor takes DDR3L, which is 1.35V:
http://products.amd.com/en-us/NotebookA ... spx?id=110
So why does the Fitlet spec say 1.5V?
Default RAM support in fitlet was changed to 1.35V. We will update specifications.
tirsojrp
Post by tirsojrp »
irads wrote:Default RAM support in fitlet was changed to 1.35V. We will update specifications.
Another change regarding fitlet specs.
No Serial port on fitlet-B. It was in the block diagram and still visible in the pictures.
Now from DDR3 1.5v to DDR3L 1.35
And "late march" is now mid April...
:cry: disappointing :cry:
Serial port doesn't appear on fitlet-B block diagrams and other official docs.
tirsojrp
Post by tirsojrp »
mbirger wrote:Serial port doesn't appear on fitlet-B block diagrams and other official docs.
It did when I bought it.
fitlet-B-top-level-block-diagram.pdf
(256.65 KiB) Downloaded 659 times
bibo01
Post by bibo01 »
irads wrote:Low voltage DDR3 may be supported. It is BIOS dependent. We will issue a list of tested DDR3 models.
I have received the Fitlet-B and I would like to buy a DDR3L module.
Have you issued the list you mention? Any suggestion for DDR3 compatible models? 1333 or 1600?
ajb
Post by ajb »
In the Compatible RAM modules spreadsheet list you state that Crucial CT102464BF160B isn't working in the fitlet, although http://www.crucial.com/usa/en/ct102464b ... uctDetails says that that 8GB memory stick runs with 1.35V. So it should run, shouldn't it?
Did you test this memory stick? Why is it listed as incompatible?
Return to “Memory”
