Fitlet fails to boot
josefg
Post by josefg »
We are using a Fitlet iA10 which was working well for some time. Recently, however, it fails booting. When turned on, it will show the BIOS screen with the American Megatrends logo. Then it will display one of the following hex codes in the bottom right corner of the screen: A1, 99 or B2. It will then fail to boot. Would it be possible to receive some troubleshooting help?
Thanks in advance.
Re: Fitlet fails to boot
That sounds like an SSD issue.
You may try reformatting and re-installing the operating system.
See instructions at http://www.fit-pc.com/wiki/index.php?ti ... :_Software
If that does not work worth trying to replace the SSD. Warranty on SSD is two years.
josefg
Post by josefg »
Thank you irads,
I am able to boot the Fitlet using an external USB key. However, the OS is then unable to find any internal disk to install to. I suppose this confirms your hypothesis that the SSD disk is dead.
josefg
Post by josefg »
Would a SSD 860 EVO SATA III mSATA 1 TB disk be compatible with the Fitlet iA10?
Return to “fitlet BIOS”
