Reducing Power Consumption
IntensePC_User
Post by IntensePC_User »
I'm trying to reduce power consumption of a fitlet-iA10. I'm running Windows 7 64-bit and with the computer at idle it is consuming 5.5 Watts (after the power supply).
This is a clean install of Windows. Nothing is connected to the fitlet; no display, no keyboard, no mouse, no USB devices, etc. The fitlet is connected to the internet using WiFi. I'm using a 64GB mSATA drive.
I've tried disabling HDMI Audio and Remote Display in the BIOS, but there was no change in power consumption.
Is there a way to completely disable the integrated video card? Any other ideas?
Thanks!
Re: Reducing Power Consumption
The system idle power levels you are seeing are consistent with the idle power levels I measured some time ago when running Linux Mint. See http://www.fit-pc.com/forum/viewtopic.php?f=153&t=5843
One thing you may try is to enter the BIOS settings and lower the TDP below the default 4500 mW level. Of course, this will lower the system's performance - possibly to a level which is below your requirements.
If you search a bit in this forum, I think you will find where others have successfully disabled non-CPU features in order to reduce power consumption. Disabling unneeded features would certainly be preferable to lowering TDP - from a performance perspective.
Here are some relevant postings.
http://www.fit-pc.com/forum/viewtopic.php?f=142&t=5809
http://www.fit-pc.com/forum/viewtopic.php?f=149&t=5670
http://www.fit-pc.com/forum/viewtopic.php?f=143&t=5654
Good luck.
Arwen
Post by Arwen »
Depending on performance needs, you could experiment with disabling a CPU
core or 2 in the BIOS. The AMD A10 Micro-6700T has 4 cores, but many tasks
only need that many for short periods of time. Thus, those tasks would take
longer. Yet overall power usage may go down.
Arwen Evenstar
Rivendale, Middle Earth
IntensePC_User
Hassellbear, thanks for the comment. Found an older post of yours and posted some results and questions there.
http://www.fit-pc.com/forum/viewtopic.p ... 991#p19991
Arwen, thanks. I'll investigate disabling a core or two to see how that affects power consumption.
IntensePC_User
So I did some quick testing.
With 100% CPU usage I get the following power consumption:
4 cores = 10.7 Watts
3 cores = 9.5 Watts
2 cores = 8.4 Watts
With a sustained load of about 20% CPU usage:
4 cores = 8.7 Watts
3 cores = 8.7 Watts
2 cores = 8.7 Watts
So for a typical use case, unloading cores doesn't seem to save any power.
Unfortunately the application I need to run is single threaded, so decreasing the TDP below 4500 sounds like a deal-breaker. But, I'll try to test that anyway.
ploubaz22
Post by ploubaz22 »
hello
I installed a fitlet pc IA10 in a sailboat and I look for the way to reduce electrical consumption.
The fitlet is windows 7
I use the navigation program that does not use much system resource
I reduced the bios power to 3,500 mW and also configure the processor core 2 and disables the sound
Still I as a 12 volt 1A consumption is 12W is too
On any other parameter I can play to reduce consumption.
Thank you
You can disable any peripheral that is not required in BIOS or device manager. You can try use Windows power manager tool.
joeroot
Post by joeroot »
Return to “General fitlet questions”
