In IPC2 produced between 12 Nov, 2015 - 10 Dec, 2015 (see SN) Ethernet FW section has been corrupted and programmed with 10 Mbps instead of 1000 Mbps.
List of IPC2 computers with respective SN requires to apply the fix:
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
For more details, including fix utility refer to the following erratum:
http://fit-pc.com/wiki/index.php/IPC2_E ... t_FW_speed
IPC2 LAN1 (I218) Ethernet controller speed fix
Engineering change notice for IPC2
