On the web site, there is a table on IPC2 models specifications for maximum resolution.
Have you got the maximum resolution the unit can support on 60HZ for both HDMI Display Interfaces 1 & 3?
To be accurate, what can I expect for maximum resolution on every single output all activated on the same time if I have all of my 3 display interfaces running on 60HZ?
Many thanks,
Ben
Display Interface 1 HDMI 1.4a up to 4096 x 2304 @ 24 Hz
Display Interface 2 DisplayPort 1.2 up to 3200 x 2000 @ 60 Hz
Display Interface 3 HDMI 1.4a up to 4096 x 2304 @ 24 Hz
IPC2 3x Displays
Re: IPC2 3x Displays
Intel doesn't provide this information, but it will be at least Full HD resolution,
HDMI 1.4a up to 1920 x 1200 @ 60Hz.
