Using single SO-DIMM memory module with fit-PC4
Issue: When single RAM memory module being used on inner memory SO-DIMM slot (P6) it may cause the system not to pass memory initialization process.
Fix: In case single RAM memory module being used, it should populate the SO-DIMM slot closer to an edge (P7) of the PCB.
Return to “fit-PC4 faults and troubleshooting”
