Hi there,
I've recently bought my Fit-PC4 Pro Barebone from Tiny Green PC and, after close to two months of delay, I've received it and I was slowly beginning to install and configure it (with Debian GNU/Linux).
Sadly, the FP4 decided to stop working and I suppose it's a power supply issue and/or something related to power.
The simptoms:
- sometimes I'm able to turn on the front light and FP4 boots, but after some seconds it stops and the lights turn off;
- I can hear some subtle noises from the power supply and I also hear the same noises from the FP4 - no other working power supplies I own generate the same noises -;
- the power supply stays on for many minutes after I unplug the power chord, still generating the noises - it looks a bit strange to me -.
Before sending back the FP4, which is very annoying, I would like to know if there's something more I can do to be sure it's a power supply issue (for example, can I use a compatible, universal power supply?)
Can you tell me if your power supply generate noises too?
Regards,
Manu
Power (supply) issue?
Re: Power (supply) issue?
If the issue with the power supply, any power supply in range 10V-16V and at least 36W should work if have compatible power plug.
If alternative power supply doesn't change the situation, please open RMA.
I have exactly the same problem, But i found that the problem not with the power supply. I think the problem related to the inside power management unit. It's really bad, because I buyed several computers and now seems two of them are dead.
Can the designers of the fit pc confirm about the faulty fitpc4 units?
We do no familiar with systematic problems of fit-PC4. The latest revisions are pretty stable.
What is exactly the problem, so that we can guide you with a solution it.
