FW Status Recovery Error
Re: FW Status Recovery Error
Yes, of course. uSVR is similar to Intense PC in that sense. Please follow the instructions of reseting the BIOS to factory defaults:
http://www.fit-pc.com/wiki/index.php/In ... leshooting
You have to short circuit two test points with some metal clip.
CKnoell
Post by CKnoell »
This method also doesn't rollback the BIOS version, but does reset BIOS settings to factory default values.
I started working with Tech support on this issue, so hopefully it will be resolved soon.
There is no rollback to previous BIOS version as we keep only the most up to date. Of course if you have the older version you can program it using the same procedure.
BIOS reset is the most complete reset you can perform to the system. Or of course override the BIOS again.
Anyway, this issue is taken care via the support DB system.
Return to “General uSVR questions”
